09-05-2021, 08:47 PM | #45 | |||||
3094
Rep 4,400
Drives: 2022 F97 X3M Comp LCI
thank you. F80 is 90% done with the mods being taken off. just exterior stuff. afterwards the car will be sold immediately. adjusted. GT4 brake duct retrofit? RWB conversion?
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
09-05-2021, 09:47 PM | #46 |
3094
Rep 4,400
car is officially no longer “stock”. got weathertech floor + cargo mats with X3MC badging (cheesy i know, but look much better) and painted front reflectors are in from IND-Distribution. of course, color match is perfect.
install was super simple obviously. it took longer for me to unwrap the packaging than it did installing them. iND can do no wrong.
IND-Distribution9602.00 Vettethret661.50 |
09-06-2021, 12:00 AM | #47 | |
Rep 3
09-06-2021, 12:03 AM | #48 | |
Rep 3
IND-Distribution9602.00 Kevin_The_Clean13385.50 |
09-06-2021, 05:31 AM | #49 |
456
Rep 352
Color combo works!
Awesome looking machine my friend - congrats on your purchase and for sharing.
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
CyGuy811830.50 |
09-07-2021, 07:01 AM | #50 |
318
Rep 183
Did BMW add some suppleness to the suspension for the LCI? Might explain your positive assessment.
Fortunately BMW seems to be course-correcting from their overly stiff suspensions across the board, which were negatively impacting handling. Cars were less planted - unsettled by mid-corner bumps, struggled to maintain contact patch, etc. Ride comfort is a secondary benefit. They addressed this in M5 LCI, G8X VS F8X, CS models. Wasn't sure if X3M LCI had the same treatment . |
09-07-2021, 09:22 AM | #51 |
BMW obsessed
9602
Rep 10,891
We are unable to order the rears just yet from BMW, however as soon as we can we will bring them in and have them painted.
Kevin_The_Clean13385.50 Poffman494.00 |
09-07-2021, 12:44 PM | #52 | |
121
Rep 121
22 F97 X3M Competition
Miss my M4 https://vossenwheels.com/galleries/3440/ |
09-07-2021, 01:58 PM | #53 | |
554
Rep 542
Drives: 2022 X3MC
EDIT: Stock weathertech with aftermarket logo from Etsy?
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI Last edited by pyo; 09-07-2021 at 03:34 PM.. |
09-09-2021, 09:39 AM | #55 |
564
Rep 323
Drives: E46 m3
09-09-2021, 09:53 AM | #56 |
Crusty Old Navy Chief
22806
Rep 1,696
Drives: 2022 X3 M40i, 1983 911SC
Standard in Canada, did not see it as an option on the UK site
09-09-2021, 02:52 PM | #57 |
26
Rep 46
09-13-2021, 10:17 AM | #58 |
3094
Rep 4,400
another mod added:
OEM G8X CF Steering Wheel Paddles Personally, I did not like the silver paddles that came with the car. They were too small and were too far into the steering wheel column. Having to do a reach around to shift is unpleasant. So I bought these. Install was simple as usual, same as any other platform. They were a bit smaller than anticipated and still dont reach as far as the edge of the steering wheel as I like, but are still much better than stock. They retain the same “clickiness” which I like, but because they DO extend slightly more than the silver paddles, the pull does feel more deliberate and tactile. The quality is great (as it should be since they are OEM) and the dimples on the back are a nice touch. I’m still searching for proper fitting OEM CF trim covers to match the paddles. The current silver/CF pictured here are a no go.
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE Last edited by danniexi; 05-12-2022 at 09:27 AM.. |
09-13-2021, 10:33 AM | #59 | |
569
Rep 987
Drives: 2022 X4 M Competition F98 LCI
For the carbon fibre steering wheel trim covers, i believe they are these numbers (upper and lower trim). However try to double check the part number for the upper piece, since they come with and without 5AU - Driving Assistant Professional. 32309882892 (Lower Trim) 32309882894 (Upper Trim, 5AU) |
09-13-2021, 10:55 AM | #60 | |
3094
Rep 4,400
as for the trim, the G8x cf trim won’t fit. the trim in the X3M is a single piece whereas the G8x is separate (upper and lower as you listed). Also, the G8x trim is too shallow as the wiring (that goes on top) will get in the way.
09-13-2021, 11:37 AM | #61 | |
569
Rep 987
However do keep in mind that the ID6 (2020) and ID7 (2021 and newer) steering wheel controls and upper part are different. So I would need to see if there's a part number difference between the G8x standard silver trim and the rest of the M line-up. If the standard trim is found on the rest of the lineup with the updated controls, then the CF trim "should" fit. Otherwise too bad the AutoTechnic trim is missing the M logo and is in alcantara instead of leather. EDIT: Had found the back of the updated OEM trim for the G05/G20/G30 and you can tell they're two piece as well (screws). Therefore theoretically the G8x trim "should" fit no problem. |
09-13-2021, 12:17 PM | #62 | |
3094
Rep 4,400
judging by the part numbers, the X5M trim are compatible, but there is no OEM trim that supports both heated steering wheel and driving assistant pro… it’s either or. ugh, i wanted to avoid aftermarket but as of this point I dont think i have a choice.
Tim@codemybimmer568.50 |
10-08-2021, 11:42 AM | #63 |
3094
Rep 4,400
so I found the "proper" CF steering wheel trim that I wanted for the options that I have (drivers assistant pro and heated)... part number: 32-30-2-471-439 of course, this part wasn't available in the US at all so I had to order on eBay and get it shipped. and of course there are "operational delays" with FedEx which I assume is a nice way of saying "we are incompetent." so after waiting a few weeks I should have the part in my hands Monday... and this is only after I find out BMWPartsPros put it up on their website and say that they should have the part in the warehouse by today. *insert facepalm emoji here*. btw this part is CF and leather with the proper cutouts for the heated steering wheel button and the lighting for the DAP package, which is why I avoided aftermarket parts (e.g. AutoTecknic) since they only have Alcantara. Minor detail but I don't have any Alcantara at the moment and the mismatch would've really bothered me. oh well. pic of it I found online... in other news, my car finally went in for the 1200 mile service. got the oil change and diff fluid change. they also replaced the battery because of the stupid "replace battery" message I kept getting. it's only been one day but I can't wait to get it back because the x3 3.0 loaner they gave me is just... depressing. thank god I commute and not have to drive that thing for long periods of time. and I finally get to push the car a bit harder. can't wait to feel what WOT feels like. I'm still shopping for winter wheels too as I have decided to put exhaust and spring modding on hold until next spring. Do I splurge on 764M wheels with the mediocre Pirelli tires or get a cheap ugly wheel from tire rack with some michelins on em... decisions decisions.
Max Well4793.00 |
10-09-2021, 12:51 AM | #64 |
3386
Rep 4,008
@danniexi - Will that steering wheel cover fit an 2001 X3 M... ? And is your LCI lowered... ?
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
10-09-2021, 12:55 AM | #65 |
569
Rep 987
@danniexi, your X3Mc is coming together really well!
The cover he has is with 5AU - Driving Assistant Professional, so it has the LEDs on the steering wheel for traffic jam assistance/parking assistance The Part Number for Pre-LCI ID7 Models and LCI without 5AU (Just 5AS or 5AT) is here - 32302459671. |
10-09-2021, 01:09 AM | #66 | |
3386
Rep 4,008
https://www.ecstuning.com/b-genuine-...r/32302459671/
