DIY: Centering the steering wheel after getting an alignment easily!
07-02-2015, 06:53 PM | #23 |
4277
Rep 9,209
To OP: you have less negative camber on the right that is why the car was pulling right and you had to hold the steering wheel slightly to the left in order to go straight. It was you camber not the toe. I would look into that and not the toe.
07-03-2015, 10:07 AM | #24 |
4277
Rep 9,209
To OP: the stalks are also not at same hieght either so centaring the steering wheel according to that is just wrong. Turn signal is higher. On a lot of makes and models the stalks are not symetrical. Measure from the floor and you will see. Honestly, why is this tread a sticky?
07-09-2015, 03:49 PM | #26 |
Rep 4
I had the same story. I made alignment in the BMW dealership but steering wheel was a bit off the center (exactly as on the picture). I came back and asked to correct that. With no questions they did it by adjusting tie rods and then checked alignment again. I guess any shop should be able to do that with no extra pay of course.
07-09-2015, 03:53 PM | #27 | |
Rep 4
07-09-2015, 05:10 PM | #28 | |
4277
Rep 9,209
Regardless, aligning the front end by adjusting the toe only judging by the position of the steering wheel it is not the correct way. Additionally, I know the photos posted are for reference but still it begs the questions: has he holding the camera perfectly leveled, was the car on perfectly leveled surface, was the tire pressure correct. Honestly, this DIY made me laugh a little. |
09-26-2015, 04:29 AM | #29 |
10999
Rep 32,881
I think it's not true about having to use ramps and not jacking the car up, the workshop manual shows the car is jacked up:
http://workshop-manuals.com/bmw/3_se...axle/page_999/ Also worth noting that the locking screw should be tightened to 40nm. Last edited by teaston; 09-26-2015 at 04:35 AM.. |
10-01-2015, 11:34 AM | #31 |
10999
Rep 32,881
10-01-2015, 12:34 PM | #32 |
Spoiler Bandit
1650
Rep 872
08-19-2016, 09:31 AM | #33 |
Rep 8
He never said the car was "pulling". The steering wheel simply was not centered. You should read a bit more before posting. Camber has absolutely nothing to do with this issue. This is exactly how all alignment shops should and will correct alignment of the steering wheel.
Current: 2011 X5 M Sport, 2011 E90 M Sport, 2004 Z4 3.0 6 speed manual
Sold: 1995 525i, 1998 528i, 2001 X5, 2004 M3 SMG, 2007 545i. |
330iToy71.00 |
08-19-2016, 09:36 AM | #34 | |
10999
Rep 32,881
Do you realise you're quoting a post from a year and a half ago!? |
08-19-2016, 09:43 AM | #35 |
Rep 8
Recently went through this on my "new to me" 2011 328i Xdrive. Steering wheel was rotated approx. 3 degrees clockwise from center when driving straight.
Couple points worth noting: 1. The car does not need to be on ramps. Access to the tie rods while the car sits flat on the ground with the wheels straight is no problem. Additionally you if you have access to a hoist there is nothing wrong with using it. Having the wheels in the air will have no negative effect. 2. Tie rods should not require any additional leverage to rotate once the lock nut is loose. Mine were easily rotated by hand once loose. 3. Rotation of the tie rods (Clockwise driver / counter clockwise passenger = counter clockwise rotation of the steering wheel. Approx 1 full turn of each tie rods will yield approx 2-3 degrees of steering wheel rotation. 4. If this exercise takes you more than 2 minutes each side to perform your doing something wrong.
08-19-2016, 09:45 AM | #36 |
Rep 8
I do. Couldn't help myself though. Been doing alignment work for many years and saw a need to simplify this and debunk some of the "not so good" information that was posted in the thread.
08-19-2016, 09:47 AM | #37 | |
4277
Rep 9,209
08-19-2016, 10:01 AM | #38 |
Rep 8
Let's assume the alignment is correct for sake of the OP's efforts to correct the condition.
Taking this to a debate on alignment settings is not the idea here... My advise to anyone with a steering wheel that's not centered would be to make sure you have your alignment correct first. If you have this condition however and you simply want to make the adjustment to center the wheel. Have at it. It's how any shop will perform the fix. If you disagree I would be curious as to how "you" would suggest correcting this issue. Maybe I'm about to learn something new. All ears...
08-19-2016, 10:34 AM | #39 | |
4277
Rep 9,209
08-19-2016, 06:51 PM | #40 | |
Rep 8
I see, your not willing to let the off center steering wheel live as a separate issue which can be solved in less than 4 minutes from the comfort of your garage. IMHO it can be delt with as a separate issue which is why I'm guessing it landed in the "sticky" section. Keep in Mind we are talking 2-3 degrees off center both in my case and from the OP's pics his case as well. I would say this is within most alignment shops tolerance given the myriad # of angles and spokes on the avg. steering wheel these days.
08-19-2016, 08:46 PM | #41 | |
4277
Rep 9,209
08-19-2016, 09:45 PM | #42 | |
Rep 8
Paid for what? In my case I simply purchased a used car which had a slightly mis-aligned steering wheel. I did not pay for a poor alignment and could assess that my alignment was fine based on several factors. Perfectly even tire wear, zero pulling in either direction and no shimy at any speed under braking or otherwise. I stand corrected on the sticky vs DIY.
Nice insult there at the end though. Not my MO and you've clearly shown your hand there. Time to move on... the info is here for others to use as they see fit which is the spirit of forums such as this. Quote:
04-11-2018, 04:49 PM | #43 |
Rep 41
Thanks nukezero for this information.
I'm going to try this this weekend, my steering wheel is crooked to the left too. So, when you took your car on ramps, did you center the steering wheel first? before to move the tie rods. Thanks |
04-11-2018, 05:02 PM | #44 |
10999
Rep 32,881
No need to centre the steering wheel. Just make sure whatever adjustment you make on one side make exactly the opposite adjustment on the other side!
