04-05-2024, 01:30 PM | #1 |
Rep 3
Giving m240i wider tires
I have a 2018 M240i I just got, and I want to start tuning it. However, I feel the stock tires can't handle the power. So, I want to upgrade the wheels and tires first but want to make sure they will fit. I was looking at the Apex VS-5Rs wheels in 18x8.5 and running 255/35 or 245/35, preferably in a 255 square setup. I have seen the Apex wheels fitment guide on their website that says you will need a minimum of 5mm spacers and 2 degrees of negative camber to fit them. Is that just the minimum I will need? I don’t know much about tires, camber, alignment, or anything of that sort, so I want to make sure that will work on my car or what I will need to make it work. Any kind of help is greatly appreciated! Thanks!
04-05-2024, 04:12 PM | #2 |
347
Rep 1,021
245 square is fairly common and you will find many examples in these threads. 255 square is more difficult. I know it is "only" 10mm, but these cars have very tight clearances, especially in the front. Expect with 255s to have to roll fenders or add camber plates - yes you might get lucky and by random luck get a combo that just works with stock - but I would not bet money on it.
Torty90.00 |
04-05-2024, 06:08 PM | #4 |
347
Rep 1,021
NP. My car is mostly stock and I find it adequate and plenty of fun. More tire is always gonna be better of course but you have to work with what you got. If I wanted to fit huge tires this would be the wrong car.
That said, if your car is not xDrive and you want to make a lot more power, you best not go square and you can fit 265s maybe even 275s in the back where you need them. If you want a road track car you will need to invest in suspension as much as engine in any case. Cheers! |
Torty90.00 |
04-05-2024, 08:36 PM | #5 | |
4473
Rep 3,506
Where are you in Jersey?
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
Kernel Kurtz346.50 |
04-06-2024, 06:57 AM | #7 |
4473
Rep 3,506
Closest to you that I know of is VAC Motorsports in Philadelphia:
https://vacmotorsports.com/ 2501 Snyder Avenue, Philadelphia PA 19145 215-462-4666
Torty90.00 |
