Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      02-26-2024, 11:53 AM   #1
jbalabas
33
Drives: f82
Conti EFC 275 on apex 9.5
I'm getting ready to get stock up on tires for the season. Do you see any issues runnin a 275 EFC on an apex 9.5 wide rim for track purposes??
      02-26-2024, 01:17 PM   #2
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
It won't provide optimum support, but it'll work ok
      02-26-2024, 02:53 PM   #3
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Really? I’m used to: 295 on 10.5”, 285 on 10” , and 275 on 9.5”.
So you’d run: 275 on a 10”, 285 on 10.5”, and 295 on 11”?
      02-26-2024, 02:58 PM   #4
SYT_Shadow
SYT_Shadow's Avatar
11490
I don't think anything bad will happen, but remember the oem uses a 10" wheel on a 265 in the e9x zcp
A 275 on a 10.5 looks awfully happy as well. I suppose 9.5 in 275 is within tire spec, but if I can get some more support, better
      02-26-2024, 04:28 PM   #5
M3SQRD
M3SQRD's Avatar
2164
BMW is all over the place on tire sizes and wheel widths. Our f22 240ix has a 245 tire on an 8” wide wheel + a 225 on a 7” wide wheel, and on our g20 340ix it has a 255 tire on an 8.5” wide wheel + a 225 on an 8” wide wheel. The base f8x uses a 255 on a 9” wide wheel + a 275 on an 10” wide wheel, and, as you pointed out, the e9x M has a 265 on a 10” wide wheel + a 245 on a 9” wide wheel. For BMW, there is no correlation between tire size and wheel width! I would not use BMW as a definitive source on tire sizes and wheel widths
SYT_Shadow11490.00
      02-27-2024, 05:00 AM   #6
BoilerUP
BoilerUP's Avatar
36
Drives: Cadillac ATS-V
I've run 275/35R18 Conti ECFs on the front of my ATS-V with 18x9.5 wheels for two years now on circuit (295 rear on 10.5s), they do just fine. Did a 1:41.5 at Barber this past Saturday on a set of ECFs on the final lap of their 26th session.
I will note ECFs run a bit wide for size, so consider that if your fitment is close.
FWIW, Cadillac's OE wheels for the ATSV are 9w with 255s front, 9.5w with 275s rear.
f80post
