Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      06-13-2021, 09:52 PM   #23
x.shell
x.shell's Avatar
6580
Drives: ▋ ▉▉
Originally Posted by x.shell View Post
Originally Posted by stevehifi View Post
So is it a problem to mount the canisters on the carbon strut bar? (Hitting the hood?) I have a 2017 would the canisters sit fine near the lights?
On more thing.
Corsa Motorsport did a couple feature videos on their shop M4 with JRZ RS Pro3 suspension. You can see that they mounted their canisters on the aluminum brace near the wipers. You would have to remove or modify the plastic in guards that covers the area.
Personally, I don't know how they fit it there. I tried and I swear the hood was hitting the canisters. But I'm gonna try to get it to fit there again. It's separated from the engine and insulated by a partition.
So I tried to mount the canisters on the aluminum strut brace last night. I really wanted it to work, but it did not. The hood does hit the canister and pushes up the hood a lot. The panel gap between the hood/fender/A-pillar becomes extremely large. Like an inch gap. That might not matter to someone running a dedicated track car (Like Corsa motorsports's M4), but the gap was too ugly for me to keep it that way. Hope this has helped.
      01-25-2022, 04:26 PM   #24
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
Drives: F80
I'm gearing up to install MCS 2WR dampers. Canister mounting locations are on my mind, especially for the front.
Being an LCI car I can't mount above the headlights. Thanks to the good people at BW I discovered this option that I wanted to share. The appearance is SO MUCH cleaner than the strut brace mount. Accessing the adjustment dials might be slightly awkward. Otherwise, I don't see any downsides. I'll likely give it a try unless anyone here can talk me out of it.
      01-25-2022, 06:52 PM   #25
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
This is actually a great idea. It also keeps the canisters further from the engine bay heat
      01-28-2022, 01:16 AM   #26
Tomclassy
Drives: Bmw m4
That is a really trick mounting location, how are you going to isolate?
      05-07-2022, 05:13 PM   #27
GuyLedouche
GuyLedouche's Avatar
588
Drives: F82/718 GT4
I did a similar set up. I have the CS hood and couldn't make them fit any other way.
      05-07-2022, 05:33 PM   #28
SYT_Shadow
SYT_Shadow's Avatar
11490
How do you put the canisters there in the first place?
      05-08-2022, 08:47 PM   #29
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
that location is directly accessible once you remove the plastic fender liner from underneath. I had my canisters there before. adjusting the knob is really hard for JRZ design type reservoirs unless you have smaller hands/ fingers, but definitely still doable.
I ended up switching to headlight location with custom bracket
Appreciate 2
SYT_Shadow11490.00
sly1types431.50
      05-09-2022, 07:29 PM   #30
ninekrpm
ninekrpm's Avatar
539
Drives: F80M3 (Track) / E92M3 (Street)
What charge cooler is that?
      05-09-2022, 08:00 PM   #31
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
EOS Billet
      08-21-2022, 12:10 AM   #32
melanthius
melanthius's Avatar
255
Drives: 2015 M3
This is exactly how my shop mounted the front canisters on mcs.
No problems making adjustments
      09-26-2022, 10:25 PM   #33
Pworld10
Pworld10's Avatar
17
Drives: 2016 F82
I need to find a shop in LA that can mount my front canisters like that! Super clean install.
      03-18-2024, 09:17 AM   #34
jfritz27
jfritz27's Avatar
1107
Drives: 2018 F80 CS
Bumping this thread as I'm getting sucked in to the black hole of a remote setup... Can anyone confirm if the standard-length reservoir lines of the rear MCS damper are long enough to make it into the trunk storage cubby if the damper is run in a standard (non-inverted) orientation? I would opt for the QDs.
The pic from sly1types makes it look like a yes but just wanted to be sure.
Thx
      03-18-2024, 09:29 AM   #35
sly1types
432
Drives: F80M3 and E46M3
Thx
Yup as long as they have QD.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104
E46 M3
F85 X5M
https://www.instagram.com/fastmacm3/
jfritz271107.00
      03-18-2024, 09:56 AM   #36
jfritz27
jfritz27's Avatar
1107
Drives: 2018 F80 CS
Thank you!
      03-18-2024, 11:25 AM   #37
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Thx
You’re fine with QDs
jfritz271107.00
      04-02-2024, 12:26 PM   #38
b_w.
399
Drives: F80 M3
how are guys securing the reservoir's to the headlights? In some pics I have seen it looks like velcro. MCS sends the little brackets with rivets. I was thinking up grinding down the headlight cap ridges and riveting it and then some double sided tape / Velcro on the other half. super tight to close the hood with much there.
      04-02-2024, 12:42 PM   #39
SYT_Shadow
SYT_Shadow's Avatar
11490
that sounds like a plan if you have a preLCI car
      04-02-2024, 01:06 PM   #40
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
Thx
Here’s how I route mine: right behind the rear wheel well cover there is a great little hole that you can use (it’s plugged with a grommet that you’ll remove), helps if you run inverted for the extra length. Lots of mounting options from there.
Current: F80
Prior: F82, F32
Appreciate 3
jfritz271107.00
The_Werm212.00
6Spd_M36.00
      04-02-2024, 02:04 PM   #41
jfritz27
jfritz27's Avatar
1107
Drives: 2018 F80 CS
Thanks for the pics!
      04-11-2024, 10:44 PM   #42
b_w.
399
Drives: F80 M3
jfritz271107.00
f80post
