10-27-2023, 05:13 PM | #4 |
5266
Rep 10,652
Stock 20” wheels are ET28. You would need 12mm spacers just to get to stock offset. Many owners with stock wheels use 10-12mm front spacers and 15mm rear spacers for a more flush look. So with the wheels you are looking at you might want 20-25mm spacers. I personally would not choose to run that big of a spacer though I have run ones in that size on one car to clear bigger brakes when running my winter wheels.
10-27-2023, 10:30 PM | #5 |
133
Rep 393
Drives: 2021 M5C
What would be the ET for a 20x10 wheel that replicates a 12mm spacer?
10-28-2023, 07:40 PM | #7 |
133
Rep 393
Drives: 2021 M5C
front
10-29-2023, 10:24 AM | #8 |
162
Rep 254
Drives: M5 / X5
ET22 I believe. https://www.1010tires.com/Tools/Whee...et-Calculator#
Inner clearance would be the same, and outer clearance should be +12mm further than stock. |
PDOT133.00 |
10-29-2023, 12:26 PM | #9 |
5266
Rep 10,652
20x10 front is 1/2” or 13mm wider than stock, half of which will be towards the fender, taking up some of the gap, meaning less than stock offset will look good. For example, with my Titan7 TS5 20x10 ET22, I do not use a spacer to push the wheel towards the fender — because the wheel is wider by about 6-7mm and offset is 6mm less than stock. With stock 20x9.5 ET28, I used an 12mm spacer that effectively reduced offset to ET16. Result is about the same visually.
PDOT133.00 |
10-29-2023, 07:47 PM | #10 |
133
Rep 393
Drives: 2021 M5C
Thanks. I plan on ordering some Forgeline wheels this winter for the next track season and want to get a square set up.
11-20-2023, 04:04 PM | #11 | |
133
Rep 393
Drives: 2021 M5C
11-20-2023, 06:03 PM | #12 |
5266
Rep 10,652
I recycled my stock size PS4 but will change to either 285/295 or 295/305 next year. From everything I have learned, 285/295 don’t rub even if lowered (I run H&R M5 springs). For 295/305 the reports are mixed about rubbing, with the fronts rubbing near full lock and a fair number saying the rears run at times. Need to look more into that.
916_M5365.00 |
12-07-2023, 05:26 PM | #13 | |
IG: @M5RCY_
365
Rep 317
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
12-07-2023, 07:24 PM | #14 |
5266
Rep 10,652
I am not sure 285/305 is a good idea due to the increased count to rear differential that could negatively affect the AWD transfer case and traction control/ABS. If I could be dissuaded from those concerns, 285/305 would probably be my first choice.
12-13-2023, 01:59 PM | #15 |
IG: @M5RCY_
365
Rep 317
Your concerns are valid but from my real life experience and research from 3 other F90 owners running 285/305, no issues to or for the drivetrain
