11-17-2020, 08:45 AM | #1 |
///Mflight Member
932
Rep 395
Drives: 2021 BMW M5 F90 Comp
21" Tire size help needed.
Hi guys i know we got lots of thread about rim sizes and tires but is always a back and forward on the subject. So what is the perfect setup for 21" that do not affect the diameter or the closest to OEM. According to this site perfect setup will be 285/30R21 front and 295/30R21. Can anyone elaborate ????
11-17-2020, 06:28 PM | #2 |
4062
Rep 5,231
I'm running Michelin PS4S in 275/30/ZR21 and 295/30/ZR21 with zero issues with AWD.
IIRC the 20" OEM setup is 275/285 (35) so staying within one size is very close to stock. I did quite a bit of research on the acceptable amount of variation from the OEM specs for rolling diameters and the 275/295 was within limits (I don't recall the % variation but do a search on here as there are several threads that discuss it). I see in your pic that you're considering a setup that has 35 profile in the front and 30 in the back but OEM keeps the profiles the same. I'm not sure that it is an issue but worth researching IMO.
Padfan9802.00 |
11-17-2020, 10:19 PM | #3 | |
///Mflight Member
932
Rep 395
11-24-2020, 10:12 AM | #4 |
1103
Rep 1,083
We recommend 275/30/21 front and 295/30/21 rear. No issues with the transfer case or TC.
You can also run 285/30/21 and 305/30/21.
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
GAMA932.00 |
11-24-2020, 10:17 AM | #5 |
///Mflight Member
932
Rep 395
Just got this directly from Michelin and according to them the perfect size is
285/30R21 and 295/30R21. |
11-24-2020, 10:18 AM | #6 |
///Mflight Member
932
Rep 395
11-25-2020, 04:19 PM | #7 |
Sergeant
802
Rep 2,509
If 275 and 295 work, wouldn't 285 and 295 also work fine? It looks like you're saying if you go 285 you should go 305 rear, but I haven't seen one M5 go 305, I think there's an issue with AWD.
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
11-27-2020, 08:37 AM | #8 | |
1103
Rep 1,083
Yes, you can also do 285/295. Just buy which combo the tire sizes are available in your desired brand. M5 AWD system isn't that sensitive, just saying withing 1.8% OD ratio between front and rear. Ferrari 488 and F8 Tributo that we're doing testings on, the other hand, is extremely sensitive to tire sizes. Although it's 2WD, it has very sensitive sensors in each corner of the car.
11-27-2020, 09:55 PM | #9 | ||
Sergeant
802
Rep 2,509
09-07-2021, 07:13 PM | #10 | |
17
Rep 203
Drives: f10 M5
09-07-2021, 07:20 PM | #11 |
17
Rep 203
Drives: f10 M5
