11-16-2020, 12:49 AM | #1 |
Sergeant
807
Rep 2,508
275/295 or 285 / 295 or 285/305?
Hey - I've posted a few times, asking questions etc, but this is tough! I can't figure out the best set up, and I'm not sure how the sizes affect the AWD, so I want to be sure I am ok.
My plan: HRE P101 in 21x10 and 21x11 (still don't know what the offset should be) Tires: Michelin Pilot Sport 4S Size: Front: 275/30/21 Rear: 295/30/21 Front: 285/30/21 Rear: 295/30/21 Front: 285/30/21 Rear: 305/30/21 I can't seem to understand why I can't go wider in the rear than stock, which is 295 when I'm going to a 21inch wheel and 11 wide. Also, if stock comes 275 and 295, why can't we stay with 20 apart on a 21inch wheel. Why is the 185 and 295 better? Help!
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
11-16-2020, 07:01 AM | #2 |
1568
Rep 29,202
But there's no 295 stock on the M5. OEM is 275 and 285, so going with 285 and 295 you are going +10 both front and rear, which I assume should be okay with the xdrive.
11-17-2020, 09:38 PM | #3 | |
Sergeant
807
Rep 2,508
I'll probably end up going 285/30/21 and 295/30/21. How can I confirm the AWD won't be messed with going up to 285/30 and 295/30, and is 30 an ok height?
11-18-2020, 06:02 AM | #4 | ||
4074
Rep 5,233
11-18-2020, 07:28 AM | #5 | |||
366
Rep 435
11-18-2020, 07:32 AM | #6 | ||||
4074
Rep 5,233
Ride may be a bit more harsh and you'll lose a slight bit of rolling diameter but it should not be an issue from an x-drive perspective and will eliminate the beefiness of the 35 profile tire.
GranitM5366.00 |
11-25-2020, 06:09 PM | #7 |
Sergeant
807
Rep 2,508
Sorry, you're right it's 285 rear, not sure what I thought it was 295.
12-12-2020, 10:52 PM | #9 |
Sergeant
807
Rep 2,508
Perfect. That's what I'm doing !
GAMA946.50 |
04-06-2023, 05:44 AM | #10 |
17
Rep 203
Drives: f10 M5
Can you do 305/295 ? Anyone experienced that?
04-06-2023, 06:42 AM | #11 |
5234
Rep 10,614
Some report rubbing near full lock up front. Some report rubbing in the rear on lowered cars when loaded. May depend on the tire used since tires can vary slightly in tread width among the same size. Also 35 series is becoming a bit oversize when you go 20mm wider. Some have gone down to 30 series.
I am thinking about these sizes. I would probably stay with 35 series. One member just installed a set, but I am not sure he has driven enough under all conditions to offer any certainty. https://f90.bimmerpost.com/forums/sh...1989424&page=4 You can search for and find a few others. |
04-15-2023, 06:29 PM | #12 | |
17
Rep 203
Drives: f10 M5
I was thinking of doing 305 back and 295 with ps4 michelin . My rims are 21×11 snd 21x 9.5...and I'm lowered with the m550i h&r spring |
11-05-2023, 04:16 PM | #13 |
112
Rep 216
11-09-2023, 12:51 PM | #14 |
22
Rep 82
I contemplated the same size but have stayed 285/30/21 and 295/30/21 on 21x10/21x11
Untitled by vosseng37s, on Flickr |
