BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    664M Wheels
      10-09-2020, 02:13 PM   #1
Virtualinsanityva
Virtualinsanityva's Avatar
Drives: 2019 M5C
664M Wheels
Can the 664M wheels off a g30 be used for the M5(f90). I am considering a winter set and wanted to make sure as its the 5x112 bolt pattern and I would be using spacers. Any one use other g30 or other BMW wheels? Looking for a more narrow 19 wheel for winter use. Thanks
      10-11-2020, 05:52 PM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Yes, they're 5x112.
      10-12-2020, 09:39 AM   #3
Virtualinsanityva
Drives: 2019 M5C
Other than the wheels being sitting inward, will it clear the calipers and brakes? Are spacers needed I wonder. I want narrow wheels for winter use(8-9.5 inch width )
      11-14-2020, 07:34 PM   #4
Virtualinsanityva
Drives: 2019 M5C
664M on Winter tires
So I took a chance and got a set of 664Ms wheels with Sottozero Square set up 245/40/19 with 8 inch wide wheels at all corners so I could rotate if needed and thinner tires should work better in snow. In theory this also would allow the rears to last longer because they could be rotated to the front. I put 30mm H&R spacers bolted to the axles and then the wheels to the spacers. Fitment seems good so far. Just wanted to pass on the idea that any g30 5 series wheel that is 19 inches or larger with a 5x112 bolt pattern can be used for our M5s.
