BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Ambient light- bronze---> pink?
      02-04-2024, 08:41 PM   #1
M5FirstEdition
M5FirstEdition's Avatar
11
Drives: M5
Pink shows up instead of bronze... am I missing something? The car was not coded to add, remove, change colors.
      02-04-2024, 08:51 PM   #2
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
4094
Drives: 2022 M5C
Bronze is the color to set to when you want an ambient color coded through BimmerCode as a custom selected color. So, a previous owner set their desired color to pink, and when switched to bronze, displays the modified value of pink.
As an example, mine is set to red. In order to get the color to be red (which I also modified in BimmerCode), I have to select bronze in iDrive.
Not a BMW guy...but certainly an M5 guy.
Appreciate 2
EM5C496.50
      02-04-2024, 09:13 PM   #3
GTTC
GTTC's Avatar
55
Drives: 2019 F90 Competition
Interesting. Would it be possible to code the cluster as orange like the ac controls?
      02-04-2024, 09:23 PM   #4
M5FirstEdition
11
Drives: M5
Originally Posted by ResIpsaLoquitur View Post
Bronze is the color to set to when you want an ambient color coded through BimmerCode to a custom selected color. So, a previous owner set their desired color to pink, and when switched to bronze, displays the modified value of pink.
I am first owner. And you are 100% right. While using bimmercode to code other stuff I hit that by accident. I just coded the car cor again to display something different and worked. Thanks so much.
      02-04-2024, 11:59 PM   #5
ResIpsaLoquitur
4094
Drives: 2022 M5C
You’re welcome! Glad it’s working.
My apologies for assuming that you were not the first owner. It was merely based on the fact that your car is an ‘18 MY and your recent join date on BP.
      02-05-2024, 12:12 AM   #6
ResIpsaLoquitur
4094
Drives: 2022 M5C
Not with BimmerCode (unless there is an expert mode setting for this, but I doubt it).
GTTC55.00
      02-07-2024, 12:12 PM   #7
Mr. Jonathan
48
Drives: 2020 BMW M5 Comp
I think it looks dope.
