02-21-2023, 12:18 PM | #23 | |
113
Rep 216
dcohen13682.00 |
02-21-2023, 02:07 PM | #24 |
682
Rep 527
Keep us posted on your renderings/design. Going with the brushed finish? What specs did you go with?
02-27-2023, 04:29 PM | #25 |
682
Rep 527
Did you end up picking out a style and ordering?
02-28-2023, 10:08 PM | #27 |
113
Rep 216
03-01-2023, 09:25 AM | #28 | |
682
Rep 527
I think the brushed look will look really good! |
03-01-2023, 05:00 PM | #31 |
682
Rep 527
MFG overseas, but very quick turnaround time, due to quick designing. Owner goes back and forth with client (me) and dials in the full spec within an hour of first discussion.
03-01-2023, 05:01 PM | #32 |
682
Rep 527
03-01-2023, 08:23 PM | #33 |
95
Rep 132
Yes, the R101 satin black.
Front 20x10 ET22 Rear 20x10.5 ET30 I also opted for the motor sport knurling and 56mm bmw centercaps. I'm hoping to fit Continental 295/35r20 and 305/35r20 tires. Some guy had that tire size setup with some titan wheels and he lowered it with the Eibach pro kit: E10-20-041-01-22 And I thought it looked really good. I'll see if I can find a picture. |
dcohen13682.00 |
03-01-2023, 08:47 PM | #36 | |
682
Rep 527
03-01-2023, 08:49 PM | #37 |
5267
Rep 10,655
I am considering these sizes but am not sure they are the best performance choice. The 305/35/20 effectively lengthens the final drive from 3.15 to 3.09, which means less torque multiplication. And you are adding only 1/2” to the wheel widths so going 20mm or 3/4” wider on the tire means the wheel is more undersized for the tire and that can mean more sidewall flex or rollover or jiggle.
My summer tires have another year of wear so I have time to read and think before buying. The 275/285 stock sizes appear a little stretched on 20x10/11 wheels so I will definitely be going wider. It’s just a question of 285/295 or 295/305. |
03-01-2023, 09:02 PM | #39 | |
95
Rep 132
03-01-2023, 09:21 PM | #40 |
5267
Rep 10,655
From what I have read, 295 fronts rub but only at near full lock. Have read only one report of rear rubbing with 305s on a lowered car, but I don’t know what wheel offset he used or the tire brand. They will definitely look meaty, but for pure looks, I would probably go 285/305.
03-02-2023, 08:10 AM | #41 | |
95
Rep 132
03-02-2023, 08:38 AM | #42 |
5267
Rep 10,655
Just the one report and that person said he had to adjust camber and still had some problems with rubbing in the rear. The same size tire can be wider or narrower depending on brand and model so maybe he was using a 305 tire that runs wide. But the several other reports I have read said no issues with 305 rear tires.
hunter879395.00 |
03-02-2023, 05:58 PM | #43 | |
113
Rep 216
03-02-2023, 06:25 PM | #44 |
682
Rep 527
I believe you could. 10mm is miniscule in the grand scheme of things. It will have a meatier look, but that is never a bad thing! Considering the factory M5 comp comes with 275/285 staggered.
