02-01-2024, 02:42 PM | #1 |
Rep 7
Used 2018-2019 M5s in 2024
Hi Everyone,
I'm new to this sub and looking to upgrade my high school car finally since 2014. I've been looking at 2018 to 2019 models and due to the car bubble bursting and these M5 prices are coming down pretty nice for buyers. I've been shopping around between the 40k to 60k mileage and I do have intentions of modifying the car at max up to stage 2 (catless downpipes, etc.). Is there anything i should really look out for that isn't the common issue such as coolant expansion leaks & low pressure fuel pump? Thanks, |
02-01-2024, 05:10 PM | #2 | |
982
Rep 1,797
02-01-2024, 08:33 PM | #3 |
699
Rep 598
Those damn 600 hp cars that dyno at about 620 at the wheels are so ridiculously slow that they need to be modified before you even drive them. Is there anything that goes bad on them ? Apart from bending rods when approaching 800hp and coolant tank not much.
02-01-2024, 09:07 PM | #4 |
5234
Rep 10,616
Great deals now on the out of warranty earlier models with higher mileage! 2018 can be found for as low as $50k with under 50k miles. Incredible cars that more enthusiasts can now afford!
02-02-2024, 04:31 AM | #5 | |
1774
Rep 3,490
Other than what you have mentioned, if you keep it stock that is about all that you need to worry about. Stage 2 with no warranty on the other hand....... |
02-02-2024, 08:56 AM | #6 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
depends what your definition of stage 2 is. catless dp are certainly not going to hurt anything. if anything the reduction of heat alone will help immensely. But if it were me, if i were doing downpipes then i would simultaneously add turbo blankets and heat tape. also replace as much plastic parts as you can. wrap all the coolant lines with sleeves etc. the coolant lines that run through the hot v are going to fail if they haven't started leaking already.
'07 Yamaha R1 (sold)
damin1540.00 |
02-20-2024, 08:37 AM | #8 | |
Rep 7
I have a 2022 Panigale V4S so I'm a bit of a speed junkie And no I graduated in 2017 but have have had the car since 2014 Last edited by damin154; 02-20-2024 at 08:46 AM.. |
02-20-2024, 08:39 AM | #9 | |
Rep 7
I'm also based on the US where we can fight for warranty claims. Generally if the dealer/shop cannot deem the aftermarket parts at fault, your warranty still applies. |
02-20-2024, 08:40 AM | #10 | |
Rep 7
I haven't seen that many reports on rod issues via the F90 on stage 2 tunes |
02-20-2024, 08:43 AM | #11 | |
Rep 7
Doing some research I see the hot V setup causes a lot of heat and I'd like to help reduce that via mods and also get some better sound over stock |
02-20-2024, 08:45 AM | #12 | |
Rep 7
I don't think i'll be looking at any new M5 unless it's a CS the depreciation hit is just too big for me |
02-20-2024, 08:52 AM | #13 | |
Rep 7
Prices have been going down drastically, hopefully they can keep going down before I find the one I want lol. |
