BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Trunk Leak
      01-28-2024, 12:10 PM   #1
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Trunk Leak
Opened the trunk on my 2018 F90 M5 today and found water on the floor. I can't see any obvious holes in the rubber seals but there is a lot of water pooled up at the bottom of the seal near the bumper. Has anyone else had this problem and is there a simple solution?
I have the BMW extended warranty but don't know if it will cover this.
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i
      01-28-2024, 12:13 PM   #2
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Images attached. The top gutter looks crusty and full of crap but the water is getting in at the bottom of the trunk lid. Battery tray is dry thankfully but the battery top is moist, probably because the water has transferred through the carpet.
      01-28-2024, 12:46 PM   #3
Alberta
Alberta's Avatar
2035
Drives: F90
Can't this be condensation ?
The battery gets warm and the cold metal around it creates condensation.
On picture 4, it's crazy to see how dirty is the rubber. I can even spot some moisture.
For sure, this car is not kept in a closed garage.
      01-28-2024, 12:55 PM   #4
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Unfortunately I don't have a garage so it's left out in the elements.
I doubt it's condensation, the car hasn't been driven in 3 weeks and there was enough water on the carpet to completely soak a baseball cap that was lying in there.
      01-28-2024, 02:37 PM   #5
carseatsm5
838
Drives: 2020 M5
I don’t know exactly but replacing all those rubber seals probably isn’t very expensive or difficult so I’d just do that.
Not sure warranty would cover this but can always try.
GTTC55.00
      01-29-2024, 10:23 AM   #6
GTTC
GTTC's Avatar
55
Drives: 2019 F90 Competition
I agree with replacing the gasket all around. I don’t know how the gasket is held in place but you can pull it slowly and see if there is a spot were is bent. In other cars the rubber has moldable metal that holds it in place and looking for rust will give you an idea where the water is coming from. I would check all other seals too just as preventive measure. Investing in a car cover would be a good way to prevent the elements from hurting your ride.
      01-30-2024, 06:30 AM   #7
Airz
11
Drives: 2015 M6 Sakhir Coupe
I had a similar issue on an M6 and it was the centre brake light seal leaking which I realise you don't have on the M5. If I was you I'd clean that top seal and then take off the inner trim from the trunk lid to give you a better view of where the water is coming from. Looking at where the water is coming down the trunk I suspect it will either be from the around the rear lights or from the reverse camera.
You should also check that water isn't pooling under the battery as it was on mine and started to cause electrical shorts once it got up to a certain level.
      01-30-2024, 07:15 AM   #8
AHall
982
Drives: 1993 Nissan 240sx
Get in the trunk with a bright light and have someone hit it with a water hose. You should be able to get a better idea.
Appreciate 2
pmsteinm316.00
      01-30-2024, 08:02 AM   #9
pmsteinm
pmsteinm's Avatar
316
Drives: 23 M5C, 19 X5
I had to do that on a new car 20 years ago. The leak was obvious once you were inside. I took it to the dealer and showed them where. Fixed under warranty.
      02-26-2024, 02:10 AM   #10
RS61
80
Drives: Audi RS6
Did you manage to work it out? I'm having what seems to be a similar issue:
https://f90.bimmerpost.com/forums/sh....php?t=2085188
      02-26-2024, 02:12 AM   #11
jhbodle
jhbodle's Avatar
146
Drives: F90 M5
Sort of.
I took it to the dealer and they found no leaks. They did say that the top seal was covered in moss and gunk (see my pics) and they cleaned that and it hasn’t leaked since.
