08-19-2022, 07:27 AM | #67 |
553
Rep 547
I have a question about the fabrication of a coolant tank in stainless steel or aluminum. Do you think there would be an issue with stainless steel / aluminum getting hotter than current plastic coolant tank? If the aforementioned tanks did get hotter, would it raise the temperature of the coolant inside the coolant tank?
Looking at the other two vehicles (VW and Toyota) in our household both coolant tanks are constructed out of plastic. But the engine compartment in those vehicles do not get as hot as the M5. My other concern would be, having an aftermarket coolant tank installed would present a problem if a warranty related concern came about. |
08-19-2022, 09:43 AM | #68 |
982
Rep 1,797
I think the warranty concern is valid. Also the repair information posted here indicates additional effects of whatever is causing this issue such as damaged charge coolers. So replacing the tank with an aluminum tank may prevent a leaking tank and the associated collateral damage to injectors, coils, etc. It may allow the additional affects of the true cause to progress to a more severe level.
08-19-2022, 11:45 AM | #69 |
2273
Rep 3,299
Now we can get into thermodynamics.
Q. Which material conducts heat better? Plastic or Stainless Steel? A. I vote Metal will conduct heat better, but I could be wrong. Q. Is the Tank a Source of Heat? A. No, hell no. The hot coolant is but because the engine is creating that heat due to combustion. The stored fluid in that tank is not a new source of heat. It does not create any more heat. Yes, heat will radiate off the tank to the surrounding structures which are likely already HOT. Thus no additional Heat "Created" and the metal tank would likely release more heat to the atmosphere than the plastic. I really REALLY doubt it would be a measurable difference. If you touch that new Metal Tank you may get a burn quicker than touching the plastic, more insulating, surface. There are hotter surfaces adjacent to that plastic tank which are radiating more heat than it does. my 2 cents, a Metal Tank would be better. Mike
09-09-2022, 02:22 PM | #70 |
25
Rep 42
My 2018 came out of warranty at the end of June 2022. Up to that point I had brought in the car three times for low coolant warning and the third time, they replaced the tank (May 2022).
Fast forward to July 2022. My first, ~$2k, out-of warranty maintenance which included replacement of all spark plugs. Pick the car up; overtake another car on the highway; car runs rough and goes into limp mode. The car has been at the dealership for two weeks now. So far one new coil and four new injectors...and on a test drive this afternoon...still running rough. The foreman has taken over the job. I am stressed out. EDIT: ~69,000km. Last edited by vanmpower; 09-09-2022 at 02:24 PM.. Reason: Adding info |
09-09-2022, 05:58 PM | #71 | |
982
Rep 1,797
09-10-2022, 07:51 AM | #72 | |
95
Rep 132
vanmpower24.50 |
09-10-2022, 11:14 AM | #74 | |
94
Rep 74
Drives: 2019 M5, Ram 1500
09-10-2022, 11:21 AM | #75 | ||
4094
Rep 3,673
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
09-10-2022, 11:42 AM | #76 | |
25
Rep 42
I, and the dealership, immediately assumed it was one of the new spark plugs; but no. The car has always been drivable during this issue unless you're hard on the throttle then things cut out into limp mode. I also think it's more susceptible to happen when I have an M-mode on. |
M5Neededi94.00 |
09-11-2022, 02:03 PM | #77 |
94
Rep 74
Thanks @vanmpower Interestingly the limp mode started after I picked my car from dealer to fix center console buttons and the gesture control. But you seem to have a different problem. I have not gotten any messages.
@ResIpsaLoquitur yeah I hope the dealer will figure it out quickly and take care of it. I will mention HPFP to them. |
vanmpower24.50 |
09-12-2022, 09:52 AM | #78 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
1) I would do Aluminum over Stainless due to weight and its ability to dissipate heat quicker. Plus stainless will corrode in the right conditions. Not sure how coolant fluid would react with it. 2)Yes a hot tank would heat up the fluid inside although i would imagine it would be negligible. Those tanks are expansion tanks and i wouldn't expect that fluid to be pulled down to the system. with that said, i would not put a metal tank inside our hot engine bay without covering it in heat reflecting tape first. 3) as with all other aftermarket parts, they won't affect your warranty unless the fault can be linked to that part. ie. if you suddenly lost all your coolant because of a leak in the aftermarket tank, then yes expect it to not be covered under warranty.
'07 Yamaha R1 (sold)
CGM18.00 |
09-13-2022, 07:18 PM | #79 |
1977
Rep 4,225
Near 21,000 miles on my 20 M5 and had to top off the coolant reservoirs yesterday for the first time. I've had to do this on my three prior M vehicles. Doubt there is a leak. The engine reservoir was the driest.
09-14-2022, 11:52 AM | #80 |
2273
Rep 3,299
Add one. 2018 M5, 46k miles (my dad's car). Coolant leak noted at routine service. (as well as bad battery internal switch).
I ordered a new coolant tank today. DIY. Mike
09-14-2022, 12:06 PM | #81 |
2273
Rep 3,299
Reading up on DIY tank replacement. Interesting that the manual has one remove the DME unit on that side, but oddly it does not appear to be in the way of removing the tank? I have to take another look to survey they job. Why removing that if it's not in the way?
Mike
09-14-2022, 12:07 PM | #82 |
IG: @M5RCY_
365
Rep 317
This EXACT thing happened to me. I had a small crack on the reservoir on the driver's side. Leaked on to my ignition coils. Warranty swapped out tank, the coils it leaked on, and their corresponding plugs. No leaks since. I would also have them check all the wiring harnesses around the area to make sure they did not fry / expose wiring.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
09-14-2022, 12:11 PM | #83 | |
IG: @M5RCY_
365
Rep 317
09-14-2022, 12:19 PM | #84 | |
2273
Rep 3,299
67,000 computers in these cars and the thing lets you run the tank that low....LOL.... Mike
09-14-2022, 12:59 PM | #85 |
4140
Rep 7,160
im curious where the low coolant sensor even is if one exists at all. its clearly not in the resevoir tank...isn't there one in the wiper fluid tank? hmm
09-14-2022, 01:28 PM | #87 |
25
Rep 42
Picking up the car this afternoon with crossed fingers. From the Foreman:
"Replaced #5,6,7,8 injectors and ignition coils. It was a connection issue due to the coolant leak in the past. the connectors had coolant residue build-up. we replaced all on this side (bank 2) of the engine. opposite side is dry no issues. The car was road tested with spirited driving and re-scanned after every road test. No more faults recurring. We are open until 5pm. Thank you for your patience on this repair." Knock on wood but I am extremely pleased with the way my dealership has handled this. |
09-15-2022, 10:58 AM | #88 | |
4140
Rep 7,160
