F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel Spacers - Good or Bad?
proTUNING Freaks
      01-24-2016, 06:22 PM   #67
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
Wink
Originally Posted by chris4prez View Post
Sorry for the Sh*tty photos as I took them with my iphone and the lighting was iffy, but you get the general idea.
If you have questions let me know.
After analyzing sh*tty photos I really think you have 15mm upfront and 12mm in the back...
Can you confirm? (Same as my current configuration...)
Originally Posted by E30toF30 View Post
I was previously running 10mm front and 15mm rear Motorsport Hardware spacers. But yesterday evening I swapped them to 12mm front and 18mm rear BMS spacers. The slight increase in size does make a pretty significant difference in visual appearance. And might I add, they look absolute BADASS haha (probably not worth it to make the swap for such a minimal change, but a buddy sold his car and gave these to me so no cost)
These are on my stock 20" staggered 624M wheels.
Front: 20x8, 225/35/20
Back: 20x8.5, 255,30/20
No issues at all. No rubbing whatsoever.
I am also lowered on h&r sport springs.
Curious to see what and how it looks like... But I still think 18 in the back is too aggressive...
Originally Posted by Anton_RU View Post
Wow, thanks for such a detailed advice and pictures!
I am definitely considering both spacers and lowering, for sure. However, I was planning to put coil overs instead of springs, because I travel a lot to different countries and need to have a possibility to adjust the height for traveling (for example Czech Republic, they have pretty harsh roads there).
Thanks again for the input!
Given your additional info here, I would further advice from NOT aligning the car, because you will be adjusting the height anyways...
If I could afford the coil overs, I would have done it too, so I think you are doing it correctly.
I can't wait to have 15mm spacers all around.
Will keep you all posted.
      01-24-2016, 08:30 PM   #68
E30toF30
122
Drives: 2016 528i Executive Edition
Originally Posted by Sleeper View Post
Any pics you could post to show this?
There are some pics in my photo gallery under Profile with pictures of the car with 15/10mm back /front.
I'll try to get pics of current setup of 18/12mm when I get a chance!
      01-24-2016, 10:38 PM   #69
DrivenByE30
France
592
Wow i have forgotten how nice your ride looks already
Cpatel39.50
      01-25-2016, 03:05 PM   #70
Sleeper
Sleeper's Avatar
660
Drives: '23 BSM X5///MC
Yeah, that'd be awesome. Your setup looks pretty bang on with the 15/10's but I'd love to see the flushness of the 18/12's with these wheels.
I have a vested interest as I think we actually have more or less the same car - M Performance Edition w/ Sparkling Graphite Metallic paint?
      01-25-2016, 08:50 PM   #71
E30toF30
122
Here are a few pictures. Quality is not great as the sun was going down, but good enough to get an idea as to what the 18mm/12mm looks like.
The difference between 15/10 and the current 18/12 is obviously a difference of mm. But when you add those additional mm together, its a significantly wider stance in a small way if you know what I mean haha.
isenc2146.50
      01-25-2016, 08:55 PM   #72
E30toF30
122
Yup! Sparkling graphite! Not too many of them around. I've only seen one other one in Vancouver in the past 10 months. And that happened only a week ago lol.
      01-25-2016, 09:08 PM   #73
E30toF30
122
Thanks! I quite like it too
      01-26-2016, 02:18 PM   #74
Sleeper
Sleeper's Avatar
660
Thanks for posting up pics. Looks perfect. BMS should send you commission on my upcoming spacer purchase.
      01-26-2016, 02:53 PM   #75
E30toF30
122
BMS probably gets way too many props on this site and wouldn't be able to afford paying out commissions every single referral haha. They definitely do something (or many things for that matter) right!
What size spacers did you end up going with?
      01-27-2016, 01:12 PM   #76
Sleeper
Sleeper's Avatar
660
Still on the fence actually. I'm trying to get my brain around the resulting offsets of the 18mm/12mm setup when considering the stock wheel offsets. IIRC, the 624m's (and all F3x stock wheels for that matter) are et36 front and et47 rear.
Using the 18/12 setup, that leaves you with +24mm front and +29mm rear. That's pretty damn aggressive lol. But judging by your pictures, there's no poke, and you mentioned there was no rubbing. So either there's way more room than we thought, or those wheel offsets as provided by BMW are lower than actual.
Thoughts? I'm still more than likely getting the 18/12's .
      01-27-2016, 01:58 PM   #77
RISEUPF30
RISEUPF30's Avatar
42
Drives: 2014 Bmw 335i Msport
Just got my Burger Tuning 12mm front / 18mm rear spacers installed.
      01-27-2016, 03:22 PM   #78
E30toF30
122
It appears a lot of people have gone the 18/12 route as yet another just above this post has done it. Those look to be factory 19's so that should give you a pretty good idea how it looks on a 19" wheel with a little higher profile tire.
Something else to consider is what type of tires you will be running. As you can see in my pictures, the stock RFT's have a very shallow sidewall compared to say the MPSS tires. Because the MPSS are much beefier tires, those might protrude out past the fender quite a bit more than my stock RFTs.
If you dont plan on running MPSS, and will likely stick with the stock RFT's, I dont think you can go wrong with the 18/12. And if you are not lowered, then definitely no issues. If you are slammed on coils or H&R super sport springs, then maybe that could cause a greater chance of rub.
Good luck with your decision!
      02-26-2016, 05:16 PM   #79
hollandog
hollandog's Avatar
Drives: F30
2016 BMW 340i  [9.00]
My RWD 340i is running on stock height adaptive suspension.
Wheels are stock 18" 398m with MPSS and 18" BBS SR with WS80 (225/45R18 square) for winter.
Anyone with this setup know if 12mm front/15mm rear would work?
      02-27-2016, 08:58 AM   #80
Sleeper
Sleeper's Avatar
660
Fine with your OEM wheels, not with your SR's. Those are +32mm all around. Pretty aggressive if you squeeze 12/15 spacers between.
      02-27-2016, 09:28 AM   #81
hollandog
hollandog's Avatar
Drives: F30
thanks for the heads up!
      03-11-2016, 01:53 PM   #82
mbanks21
1268
Drives: 2015 335i MSport
I didnt read the whole thread but does anyone know why spacers for E90 wouldn't fit on an F30? Is it just the thread size?
      05-23-2016, 01:04 PM   #83
SMC23
180
Drives: Subaru XTrek / X5 40e
After reading up on F30 spacers I have settled on H&R front 12/ rear 15. Quality is outstanding!
      06-21-2018, 02:46 AM   #84
TEST DRYVER
TEST DRYVER's Avatar
Drives: 2019 Porsche 718 Cayman GTS
I've been looking and reading here. I just picked up a 2015 335i M-sport with adaptive suspension on OEM 19's (style 704, I believe). This will be our family car, so I'm not looking for a crazy power, really loud-smelly, harsh riding car. I am looking to improve upon the already positive attributes of the F30. I just sold a heavily modded Golf R APR Stage lll, but we had an X5 for our family car, so I didn't mind an aggressive setup for the R.
I just placed an order for a Bootmod3 stage 2 tune, AR design catted downpipe, and VRSF spacers (10mm front along with 12mm rear). I was planning on placing the order with 12mm front and 15mm rear, but Mike from Extreme Power explained that 12 and 15 would be slightly aggressive. He only mentioned this because I explained that this would still be a family car that my wife would be driving at least half the time. I also plan to burn through these RFT tires and go with a non runflat, one size larger. Currently, the tires are OEM 225 front and 255 rears: Bridgestone POTENZA S001 RFT. I plan to go to 235 front and 265 rear non runflat within the next year. Please forgive the stupid question, but do you think I'll be ok with the order I placed. I am not looking for any type of rubbing or fitment issues...
      05-10-2022, 07:08 PM   #85
320dgrey
Netherlands
Drives: BMW 320d
Hi guys,
I have 2014 320d M package with M suspension. How do I know if it is adaptive? I have the comfort and sport mode button. Does that do anything with the suspension? From the iDrive settings it looks like it does.
Is it true that the M suspension is 10mm lowered than without?
And what is the best/max spacer size for 403M 19” staggered setup rims without rubbing, rolling fenders, adjust liners or whatsoever ? Originally it has 8J front and 8,5J in the back.
These are the option I have according to vin decoder on internet:
S337 M Sports Package
S704 M Sports Suspension
S715 M Aerodynamics Package
Thanks for any advise!
      06-01-2022, 11:58 AM   #86
320dgrey
Netherlands
Drives: BMW 320d
Originally Posted by 320dgrey View Post
Hi guys,
Any help out there?
      06-01-2022, 01:04 PM   #87
WagonHo
WagonHo's Avatar
554
Drives: BMW 330i Sport Wagon
Not a direct answer, but I hate waiting, too.
I believe that S704 is NOT adaptive, but the standard M Sport suspension. I think adaptive suspension was an additional package/cost and was option code SA2VF.
I can't speak to the 10mm lower, as I drive a (formerly) sky-high xDrive/MSport vehicle.
For spacers, I have 400M winter wheels, square, and run 12mm spacers up front and 15mm in the rear to make them flush with the fenders. My 400Ms are ET 34, front and rear.
My summer wheels are 19x8.5 ET 35/19x9.5 ET43 with no spacers and they run flush to the fenders with no rubbing or fender mods.
I read that 403Ms are ET 36/47, respectively, if that helps.
I hope it does, at least a little. Good Luck.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota
2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019)
2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016)
BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021
      06-02-2022, 01:42 PM   #88
320dgrey
Netherlands
Drives: BMW 320d
WagonHo,
Thanks for your reply appreciate it!
In the wheels i see IS36 and IS47. Is that the ET value? In that case how far can i go to get the wheels flush with the fenders?
f30post
