F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Fsc code Generator
GetBMWParts
      04-16-2014, 03:43 PM   #23
nvy
nvy's Avatar
Drives: 11' F10, 07' E90, 04' E46
ok someone please walk me through this. Im using Windows 7 32bit.
1. I have EDIABAS install per the instructions.
http://bmwcoders.com/forum/bmw-gt1-o...-software-328/
2. I have ENET cable from One-Stop-Electronics
3. I changed change FSC.bat to "0x2D ox08"
4. I have North America Premium 2014-2 extracted on flash drive.
What now? Do i just connect the eNet cable to the car and USB to the laptop? Any left to configure?
      04-16-2014, 04:32 PM   #24
hsk1610
108
Drives: 2013 328i xDrive
Once you have the FSC code, jot it down somewhere. Plug the USB into the glove box port and wait for the Nav to recognize it. It will read the files from the USB drive and say update is available. Then you just follow the prompt on the Nav display.
Appreciate 2
      04-16-2014, 04:36 PM   #25
Frogman
Drives: 2012 F30 328i
Follow the instructions in the video here:
http://www.f30post.com/forums/showpo...6&postcount=22
Basic Steps:
1. Read the navi FSC using the swid_reader.
2. Disconnect your latptop from the car (it's no longer needed).
3. Decode the FSC code using the supplied b64dec tool.
4. Feed the decoded fsc code to fsc.exe along with the region (0x2d) and map sequence code (0x08 for NA Premium 2014-2).
5. This will output the "short" FSC code for your car.
6. Plug the USB stick with the maps into the glovebox USB port with the ignition on.
7. The car will say that an updated map is available. Click OK and it will prompt you to enter the short FSC via iDirve.
8. Enter the code output by the FSC generator and if everything is good, it will start loading.
Appreciate 2
      04-17-2014, 01:49 PM   #26
alienranch
19
Drives: 2012 BMW 335i
Awesome!
      04-17-2014, 02:07 PM   #27
nvy
nvy's Avatar
I'm running into a problem. When I hit "connect" on the SWID, I get an error. It will not connect. Is there additional configuration on EDIABAS other than the install?
I was reading on another forum and they said to change a few settings on the EDIABAS.ini? What settings are those?
IP? Server?
      04-17-2014, 07:21 PM   #28
hsk1610
108
IP? Server?
I am also having issues. I can connect but does not read the VIN.
Only settings that needed changing, if at all, was INTERFACE = ENET in Ediabas.ini Everything else at default should be ok according to other forums.
this is my error message:
Starting...F-serie...
Ediabas version: 7.3.0
Ignition: = OKAY
Trying...
Reading CAS...
System.Exception: SYS-0005: OBJECT FILE NOT FOUND
CAS: VIN -
Reading CIC...
CIC: VIN -
      04-18-2014, 02:25 PM   #29
Kaitain
7
Drives: Estoril Blue II F30 M Sport
Ignition: = OKAY
Trying...
Reading CAS...
CAS: VIN -
Reading CIC...
CIC: VIN -
I believe you are missing a file. I think I had this error also, so I took my older
EDIABAS folder and dropped it on the newer one. I only let it add new files and kept the newer files, do not overwrite files. I ran the program again, and it worked.
      04-18-2014, 04:10 PM   #30
hsk1610
108
Thanks, from the BMW Standard Tool, also needed to install NCSEXPER. Also if you manually installed or copied api32.dll into your Windows directory, that should be removed as well. Finally got it to work.
      04-20-2014, 12:01 PM   #31
Kapitein Iglo
16
Drives: F31
If you have NBT, you're running into the same problem as I did.
You need a newer version that is compatible with NBT
      04-21-2014, 03:22 PM   #32
Steveo
Steveo's Avatar
153
Drives: M4
I have NBT, will the generator posted in first page work?
what are the exact instructions to get this working?
      04-23-2014, 04:32 PM   #33
Dr.Ho
Drives: F30 320d (328d)
If you use E-SYS, you can read the nav enabler FSC code by using the program as Aritaurus decribed:
Originally Posted by Aritaurus View Post
Just an FYI for those of you who have NBT or can't get SWID reader to work at all.
You can actually grab the 1B or DE file from E-sys by doing the following:
FSC Extended
Base variant 0x63 (For HU_CIC or HU_NBT)
Click Identify
Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <--- This is the App for your Nav enabler
Upgrade Index 0x1
Move Store FSC from the left to the right
Click Read
Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN.
I've tried this method for both CIC and NBT and it works.
Then, proceed with step 2 [DECODE FSC] in the video.
      04-23-2014, 04:36 PM   #34
Steveo
Steveo's Avatar
153
Drives: M4
Thanks,
this will get the FSC code, where do I download the map from or does the car do it?
      04-24-2014, 12:13 PM   #35
Steveo
Steveo's Avatar
153
Drives: M4
OK, I managed to get the fsc code out of car using E-Sys.
problem is I cannot use the other tools as I have 64bit system
Could someone generate the code if I send the car fsc code to them?
I have NBT and require Europe NEXT map.
      04-24-2014, 01:21 PM   #36
Dr.Ho
Attach your FSC Code as a ZIP file to your reply, and I will try my best.
Or download the new Version, capable of reading CIC and NBT:
FSC Code Generator
      05-05-2014, 10:30 PM   #37
335i_4D
Now in the dark side !
335i_4D's Avatar
65
Drives: 2011 911S 997.2 Cab
Does someone have a link to download EDIABAS ?
Been searching, and can't seem to find a viable one.
Thanks in advance !
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      05-27-2014, 05:27 AM   #38
michalkow
Poland
Drives: e61
What when vin in cic is different than vin in cas,
It generates bad code.
Which VIN I need to change?
      06-04-2014, 12:06 PM   #39
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
am i doing anything wrong?
the fsc looks weird and the decoder says it has no base64 data
      06-04-2014, 07:14 PM   #40
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
671
Drives: 2020 G20 320i M Sport
You need to encode it to Base64 right after or else it won't work with the generator.
http://www.motobit.com/util/base64-decoder-encoder.asp
Use this website, load the .fsc file in there then convert and open a new text fiew and copy everything into one line and copy the new file over the old .fsc file.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
Appreciate 2
      06-05-2014, 07:43 AM   #41
pikcachu
pikcachu's Avatar
1406
ah awesome thanks!
      06-05-2014, 12:53 PM   #42
MyFastM3
65
Drives: m3
Just a random thought ...... would this tool not work for other FSC codes? Like the collision warning system ?
      06-05-2014, 01:58 PM   #43
xman2k2
Drives: 2010 328i
Is it possible to generate the FCS code file without connecting to the car? Otherwise how are these people selling FCS codes with just your VIN??
      06-05-2014, 04:14 PM   #44
Frogman
The people selling FCS codes by just supplying them the VIN have access to the BMW portal that can supply the cars' FSC signature file.
That's the equivalent file that is read from the car using the reader program.
Appreciate 2
f30post
