01-04-2018, 06:16 PM | #90 |
123
Rep 565
01-05-2018, 05:59 AM | #92 |
123
Rep 565
You have HU_ENTRYNAV2, which is a successor to HU_ENTRYNAV. It should be able to be coded for an 8.8" screen, however, I'd first check the coding via eSys and ENET cable.
EDIT: The non-touch 8.8" screen for your head unit should be this one: 65506822626. However, the older models *may* also work, but we haven't tried them with the newer head unit, yet. Last edited by MarkoSK; 01-05-2018 at 06:12 AM.. |
01-06-2018, 02:17 PM | #94 | |
Rep 23
I have a HU_entrynav with 6.5 screen and I´m thinking to change to 8.8. Where are this codes if using esys? Do I have to pay 100 euros if I would like to code with Esys? Correct? Many thanks in advance? |
01-06-2018, 03:07 PM | #95 |
123
Rep 565
You just need an ENET cable or adapter (ebay example), then just install the software and follow the included guide. If you do it yourself, the cost is just $20 (price of the cable).
01-06-2018, 03:32 PM | #96 | |
Rep 23
I have Enet cable, not the screen yet. I don’t know where is those codes: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display |
01-09-2018, 05:32 AM | #98 | |
Rep 24
01-09-2018, 05:44 AM | #99 |
123
Rep 565
Here are the installation instructions from BMW.
02-06-2018, 10:43 PM | #100 |
Rep 3
02-07-2018, 08:07 AM | #101 | |
123
Rep 565
Best way is to check via ENET cable and eSys software. If your car was made after 7/2014, there's a good change you have HU_ENTRYNAV. Some cars (with basic/business nav) have them sooner, from 4/2014). |
02-11-2018, 05:51 PM | #102 | |
95
Rep 228
I finally got the enemy cable what else I need check besides the resolution size of changeable? |
02-12-2018, 06:59 AM | #103 |
123
Rep 565
Just check if you can see and select/change these two values:
HU_ENTRYNAV2 > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_ENTRYNAV2 > 3001 EXBOX > DISPLAY_VARIANTE = breites_display |
02-12-2018, 10:19 AM | #104 |
Rep 2
Hi All, I have a F31 with entrynav and about to buy a bigger screen, my current one is 65509322120, which ones can I upgrade to - seen some 8.8's that have come off a F45 and F21 - would these work?
02-12-2018, 02:17 PM | #105 |
123
Rep 565
02-13-2018, 05:02 PM | #106 | |
Rep 2
02-16-2018, 12:02 PM | #108 |
95
Rep 228
Good news is it has both available however resolution size only displays "6.5" "7.X", "8.8", and "10.X" witn no resolution behind it.
02-16-2018, 06:07 PM | #109 |
123
Rep 565
02-16-2018, 08:02 PM | #110 |
95
Rep 228
