01-10-2016, 03:27 PM | #1 |
263
Rep 1,130
Drives: '16 340i AW MSport
Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
What parts are required other than the screen itself?
What codes are needed? My plan is to buy the 8.8" screen on ebay, is there a specific part number i need to look for? What other requirements are there to upgrade? This should work with the latest version of hardware and HU_ENTRYNAV with no navigation? From what I understand this is what I need to do Screen Swap then code code: HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480 HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display Last edited by kromix; 01-10-2016 at 05:06 PM.. |
01-11-2016, 02:08 AM | #2 |
67
Rep 263
These are exactly the 2 FDL codings you need.
Then connect L7 High 8,8" screen and enjoy |
zrile100.00 David Kunitz697.50 |
01-11-2016, 07:13 AM | #3 |
263
Rep 1,130
Awesome can't wait!!! Buying the screen now!
Thanks for all your help TePee!!! |
01-12-2016, 07:07 AM | #7 |
263
Rep 1,130
01-26-2016, 09:27 PM | #8 |
38
Rep 130
01-26-2016, 10:41 PM | #9 | |
263
Rep 1,130
DIY coming soon in about 2-3 weeks |
01-27-2016, 12:27 AM | #10 |
38
Rep 130
Great! I'm now not sure if HU_ENTRYNAV appears for 3/4 series only or even 1/2 series will have this after 7/2014 production.
01-27-2016, 06:25 AM | #11 |
67
Rep 263
I can also confirm that you don't need another cable. Just the big screen and the 2 FDL codings.
You should find Entrynav from 3/2014 or 7/2014 on, depending on BMW series 1/2/3etc. and whether you have navigation (Business) or not (Radio Professional). |
02-09-2016, 05:31 AM | #12 |
554
Rep 646
How do we check the system version? I have a 10/2012 F30 with Business navigation (6" screen) - I know it's a retrofitted system, so it might be a tad newer than the car. Am I able to switch the screen to a big one? Would LOVE that upgrade!
| 2021 Tesla Model 3 |
02-09-2016, 07:55 AM | #14 |
67
Rep 263
Guys as wrote before you need to have HU Entrynav which was introduced from production 2014 March or July on (depending on if you have Business Nav or just Radio Prof, both are Entrynav).
If you have 2012 year, then you can't have Entrynav, thus no 8,8" screen retrofit possible. |
02-10-2016, 04:13 AM | #15 | |
554
Rep 646
04-03-2016, 06:07 PM | #19 |
263
Rep 1,130
Sadly too expensive for you, would need HU_ENTRNAV, or retrofitting the CPU that powers the car..... It started in cars I believe July 2014 or something around then.
07-03-2016, 12:37 AM | #21 |
114
Rep 157
I'm about to upgrade the 6,5 screen on my 08/14 (HU_ENTRYNAV) F31 Touring to the 8,8 one.
My car is pre-LCI and I have already retrofitted the BMW Integrated Navigation System on my 6,5 screen. Do you think that a 8,8 screen from an LCI model (part number 65509387453) can be retrofitted to my car or I need to instal the 8,8 screen from pre-LCI model (part number 65509292248)? Are there significant differences between these two 8,8 screens? Also the split screen function of the 8,8 screen needs some coding to work or it is automatically set as a menu option as long as the 8,8 screen is installed? Any help would be hugely appreciated. Thanks in advance. |
07-03-2016, 05:11 AM | #22 |
67
Rep 263
The LCI 8,8" screen won't work with your HU Entrynav! It uses different voltage. You have to install the pre LCI screen.
Normally when you code 8,8" screen and broad display everything will work in proper way, including split screen etc. The question is whether this is the case or not when you have Integrated Navigation? |
