01-06-2021, 08:26 PM | #1 |
Rep 9
Turning off active sound design
Will there be any enhancement in the quality of the sound coming out of the speakers by turning off active sound design. Since the car is using the speakers to pump fake engine noices inside the cabin (B&W)
01-07-2021, 03:49 AM | #3 |
2511
Rep 4,381
Its a much pleasanter cabin environment with it disconnected.
I would say that music does sound better without ASD. |
Resjudicata1603.00 |
01-07-2021, 04:59 AM | #4 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
I doubt it affects the quality or performance of the speakers or amp much unless you have the music cranked up to near the limits of what it can do, which isn't realistic anyway. But any unnecessary background noise affects what you hear when you're listening to music, for obvious reasons. So if you're asking does it affect the music... technically, probably not, but generally, yes, if that makes any sense. I have mine turned off. Makes it a little more pleasant.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
01-07-2021, 12:41 PM | #7 | |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
buy veepeak OBD2 Bluetooth module You will have option in the app to disable ASD. Also u can download bimmer code app as well to code the car.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
01-08-2021, 01:20 AM | #11 |
369
Rep 1,887
01-08-2021, 03:28 PM | #12 |
101
Rep 238
I turned mine off with Bimmercode, and than the car became completely silent. Seriously without the ASD there is not V8 Rumble...lol. I also have the Remus axelback and honestly when I turn off the sport exhaust button it's pretty much the same as me turning it off in the bimmercode app. So in the end I normally drive with the ASD on and if cruising on highway long trip I usually turn it off. Also I do not hear any difference in sound quality.
arlind9489.00 |
01-08-2021, 05:31 PM | #13 |
2272
Rep 3,297
The switch is the easy way. When it's off, the outside noise is also decreased. The backfires are off too. So if you disable it with Bimmercode, which I did when I first got the car (and did not even now about the downshift backfires etc) it will be off. After getting the car back from service and hearing it on again, I realized it was better left functional.
Mike
bubbaboy107.50 |
01-09-2021, 12:07 AM | #14 |
84
Rep 234
ASD was in pre 2020 models, correct? I turned it off via a fuse in my old X4MC, and when I wanted to unplug the module in my 2020 F90 found out it wasn't under the trim.
01-09-2021, 07:37 PM | #15 |
377
Rep 541
Your M5 definitely still has ASD aka the fake speaker sound they pipe in. Next time you drive it, toggle the exhaust button on and off with the windows up and you will hear an immediate difference.
01-10-2021, 09:08 AM | #17 |
475
Rep 608
By turning it off you'll lose the backfires. Or at least I did.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
01-10-2021, 05:14 PM | #19 |
32
Rep 36
I just want to confirm that when coded off (as opposed to using exhaust button) you lose backfires.
I hate the idea of sound over the speakers, but would like whatever natural sound is produced. |
01-10-2021, 08:56 PM | #20 |
219
Rep 291
I coded the ASD off when new and backfires/pops are still there. The ASD is a joke, it sounds like the exhaust is coming from the front of the car
2023 M5 Comp Skyscraper Grey,Executive Pack, Drivers Assistance, B&W, 789's. |
01-10-2021, 09:54 PM | #21 | |
1603
Rep 2,935
Roll down your windows, or setup a microphone or camera outside your car. It's there and 100% as loud either way. Coding it off just removes it from your car stereo speakers. Interior only. Has nothing to do with the engine or exhaust. |
thekronoschef182.50 |
01-10-2021, 10:49 PM | #22 | |
377
Rep 541
