BMW M5 F90 (2018+) General Forums F90 M5 vs...    My F90 vs 800+ RS7, C6 Z06, 1000+ DSM 1G
      12-16-2020, 04:31 PM   #1
MostStockF90
Drives: 2019 BMW M5
First two videos is against the RS7
Third video is against the C6 Z06
Last two videos is against the DSM talon
      12-22-2020, 02:01 PM   #2
The Dane
Denmark
112
Drives: 2015 m5 cp
Any mods on your f90 ?
      12-27-2020, 02:22 AM   #3
MostStockF90
Drives: 2019 BMW M5
E30
catless downpipes
modified exhaust
      01-07-2021, 11:40 PM   #4
FastFive
28
Drives: Bmw ///M’s
Which tune?
      01-20-2021, 07:51 PM   #5
SatinblkF90
SatinblkF90's Avatar
134
Drives: 18 F90 M5
Surprised that z06 kept up as well as it did. E30 stage 2 f90 is a huge jump from 93 stage 2.
      01-20-2021, 09:53 PM   #6
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
Do you how big of a difference between 93 vs E30?
      01-21-2021, 12:08 AM   #7
SatinblkF90
134
Drives: 18 F90 M5
From what I've seen about 50+hp as it advances the timing quite a bit. Of course also depends how aggressively it's tuned for it.
      01-21-2021, 07:35 AM   #8
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
Ah ok. I did see RKTunes managed over 50whp and over 100torque over 93. I know there was a member on here that was getting same or worse numbers in terms of 60-130.
      01-21-2021, 12:07 PM   #9
SatinblkF90
134
Drives: 18 F90 M5
It certainly should be making much faster times on e30 with that big of a power gain, maybe something was wrong with the car, but it cannot be right!
I'd personally stay on 93 anyway to keep the engine safe (weak rods) as e30 is certainly pushing the upper limits of the motor.
GranitM5366.00
      08-12-2021, 04:27 PM   #10
MostStockF90
Drives: 2019 BMW M5
Originally Posted by FastFive View Post
Which tune?
DME Tuning
      08-12-2021, 05:48 PM   #11
TrevorM3
3322
Drives: 6.3 AMG
The C7Z is no slouch, even in stock form. I ran what was probably a 750hp F90 (who is on this board) From a 40 roll, i jumped out immediately, was kept at my back bumper until he passed me at 135 like i was standing still.
Weight helps a little.lol
      08-12-2021, 09:26 PM   #12
brad65ford
256
Drives: 2022 M3
[QUOTE=TrevorM3;27914150]The C7Z is no slouch, even in stock form. I ran what was probably a 750hp F90 (who is on this board) From a 40 roll, i jumped out immediately, was kept at my back bumper until he passed me at 135 like i was standing still.
Had a bone stock 16 z06 a8 recently and did a 93 file custom tweaked tune and did a lot of dragy runs with it. While it did very similar in 1/4 mile and 60-130 as our 19 M5 comp w/ a 93 OTS stage 1. The M5 comp is a little bit stronger, mostly do to the LC helping. haven't done a 60-130 from a roll yet with the M5 but I have a feeling its not as fast as when using LC since shifting speed in that condition is faster.
      08-13-2021, 03:02 AM   #13
SatinblkF90
134
Drives: 18 F90 M5
[QUOTE=brad65ford;27914892]
I think the LC only gives faster shifting for 0-60 but not once your past 3rd gear. A roll start also doesn't create as much heat etc.
I've done dragy on my tuned f90 and rolling always gives a faster 60-130mph than a dig by a few tenths.
It should be running faster than the c7 on the roll, let's see after you test it out what it does.
      08-13-2021, 05:57 AM   #14
TrevorM3
3322
Drives: 6.3 AMG
C7Z (Auto) completely dies up top when going 3rd to 4th. Manaul still pulls, but it's negated due to MT. Stupid gearing in the auto really. But car still had some serious balls.
      08-13-2021, 06:07 AM   #15
brad65ford
256
Drives: 2022 M3
Yes the auto gearing is a little high after 4th, also if you stage 3 areo package doesn't help. Mind had the z07 package but I removed the rear wing-lets which helped greatly for top end.
      08-13-2021, 06:09 AM   #16
brad65ford
256
Drives: 2022 M3
Wow that is a shocker regarding from a roll vs a dig. Usually Digs are faster 60-130 because of the mode the trans is in for best times. In Manual you can feel and hear (trans farts) that the trans is shifting slower.
      08-14-2021, 01:07 AM   #17
PaLaKaT
71
Drives: 2022 X6M
Tue, my best 60-130 were from a LC. Trust me i did a ton of 60-130 🤣
      08-15-2021, 08:25 AM   #18
edwarjejeega
edwarjejeega's Avatar
Drives: '19 M850i, '18 X6M, '16 M4
Yes, which is why you start in manual from a roll e.g (2nd gear, 35-40 mph) and when you floor it, you slap it back into drive so it could shift on its own.
Same slope, same day, same DA, same F°, the difference on dragy was 0.46 60-130mph from manually shifting as good as possible, to slapping it back into "D"
      08-15-2021, 05:49 PM   #19
brad65ford
256
Drives: 2022 M3
I find this hard to believe, may be true though it doesn't make sense. All LC's activate a different shifting allotment regarding torque / shift speed to get the best run times. You can tell by listening to the shift farts (slower shifts in D when not in LC mode)
      08-16-2021, 02:11 AM   #20
SatinblkF90
134
Drives: 18 F90 M5
But those faster shifts aren't they only for the first 3 gears? 60-130 are gears 3-5 so I don't see how LC helps it there.
