BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Low tire pressure warning at startup
      09-23-2020, 06:47 PM   #1
TwinWhistles
23
Drives: BMW M5 F90
For the last two days when I start the car, I've been getting a low pressure warning on the iDrive screen. When I click the either of the two links on the screen (Owners Manual or Tire Pressure Menu) I get alerted to only doing it while operating safely, even though I'm stopped and in park. Also, when I check the tire pressure through the tack screen it shows all my tires being 33psi, which is recommended. Anyone have a solution? Pump the tires up a few more psi?
Thanks
      09-23-2020, 09:16 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Thanks
"If" you can figure out how to get in the Tire Menu menu I would try performing a reset and see if that resolves. You'll need to be stopped to start the reset and then you'll need to drive while it reads the pressures.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      09-24-2020, 10:35 PM   #3
Joey.Donatelli
Joey.Donatelli's Avatar
Drives: M5C
Had to do the same on mine. Do a reset and you should be good.
      09-29-2020, 04:15 PM   #4
TwinWhistles
23
Drives: BMW M5 F90
Performed the reset and good to go. Thanks!!
