02-07-2021, 01:28 PM | #89 |
141
Rep 401
02-07-2021, 05:37 PM | #90 | |
1692
Rep 3,200
Who did the work? OSS designs? |
02-08-2021, 01:24 AM | #91 | ||||
42
Rep 38
yes,from oss designs |
02-08-2021, 05:05 PM | #92 | |
441
Rep 891
02-23-2021, 10:53 PM | #93 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
Any pics available or diy video yet? I'm looking to get euro version have a coder as well but would be great if we can see what needs to be done. Thx
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
02-24-2021, 04:13 AM | #94 |
Rep 41
Yes also very much interested. Getting the parts is straightforward but not being stuck with expensive paper weights is the concern if coding and wiring is a major hassle. I wonder if the same coding and wiring is needed in the LCI US versions with the red blinkers. After seeing them it seems that they also have the indicator strip and brake light when the turn signal is on. Would also be nice to finally get LED reverse lights with this upgrade
02-24-2021, 06:59 AM | #95 | |
60
Rep 112
I found the retrofit instructions in German and translated it to English. Some things got lost in translation with formatting issues. Also found a site in Korean with some pictures, which I converted to English. If you open it in Google Chrome it will automatically translate it. https://m.cafe.naver.com/ca-fe/web/c...seCafeId=false Hope this helps. Last edited by CarFreak; 02-24-2021 at 07:10 AM.. |
02-25-2021, 12:07 PM | #96 |
1105
Rep 1,607
Based on this I just need to figure out what pins for the inside lights? No need to go to bdc.
GT
Maverik2594140.00 |
02-25-2021, 03:59 PM | #97 |
1658
Rep 1,536
02-26-2021, 08:09 PM | #98 | |
1105
Rep 1,607
GT
02-26-2021, 10:23 PM | #99 | ||
1658
Rep 1,536
Then, there are 2 holes for each pin. Use the smaller hole, and insert a small screwdriver in there, that will allow you to unlock the metal pin. And then you can pull it out to rearrange. |
02-26-2021, 10:40 PM | #100 |
60
Rep 112
Just installed US lights.
https://youtu.be/2Ta8HrLv79w What did I do wrong to the trunk lights? Or will coding fix this? I also didn’t run wires to the BDC as I was told it’s not needed on US cars with US lights. Last edited by CarFreak; 02-26-2021 at 11:19 PM.. |
GTATX1105.00 |
02-26-2021, 11:41 PM | #101 | |
1658
Rep 1,536
02-27-2021, 02:46 AM | #102 | |
60
Rep 112
US plugs only have 4 wires and the colors are different from the left light to right. Could you please confirm the colors from 1-6 on the left and then on the right? Left • YELLOW/BROWN wire to 2 • YELLOW/BLACK wire to 3 • BLUE/RED wire to 4 • BROWN wire to 6 Right • BLUE/BLACK wire to 2; • YELLOW wire to 3; • BLUE/WHITE wire to 4 • BROWN wire to 6 Last edited by CarFreak; 02-27-2021 at 08:31 AM.. |
02-27-2021, 08:55 AM | #103 | ||
1658
Rep 1,536
• YELLOW/BROWN wire to 2 • YELLOW/BLACK wire to 3 • BLUE/RED wire to pin 5 • BROWN wire to 6 Right • BLUE/BLACK wire to 2; • YELLOW wire to 3; • BLUE/WHITE wire to pin 5 • BROWN wire to 6 To code it, reach out to www.bimmercoder.com |
CarFreak60.00 |
02-27-2021, 09:28 AM | #104 | |
60
Rep 112
02-27-2021, 11:20 AM | #105 | ||
1658
Rep 1,536
So far nobody was able to figure how to make USA red lights work with welcome lights, without compromising the other functions of the lights. So when you are testing your lights, test them after your welcome lights turn off. Start the car only after welcome lights shut off. Also I would suggest to turn off welcome lights in idrive for now. Also based on your video, the reverse bulbs were not coded and changed to LED type, as I see them blinking periodically |
02-27-2021, 12:53 PM | #106 | |||
60
Rep 112
I wanted to program it, but the coded said I need to run wires to the BDC. Without it, the outer turn signals won't work. I took your advise and turned off the welcome light. Please post a video of how yours is working after coding and no BDC wires. |
GTATX1105.00 |
02-27-2021, 01:10 PM | #107 | ||||
1658
Rep 1,536
Msg this guy on Whatsup, his name is Vick, the same person I linked above from bimmercoder. He will get you coded and everything will work 100%, except the welcome lights +60 12-396 9654. |
02-27-2021, 01:43 PM | #108 | |
60
Rep 112
03-06-2021, 03:24 PM | #110 |
1105
Rep 1,607
I just got mine from bmw Yesterday. Gave them part numbers on Wednesday and it was here Friday.
Side note: there is no welcome light fix yet with USA spec lights. Our lights have only 4 connections on the light side and only 4 wires coming from bdc. Even if u have 5 wires coming from bdc it wouldn't matter as lights have only 4 connections. I have worked with Vick with opening bdc and changing pins but it wasn't any use.
GT
Alberta2038.00 |
