09-06-2020, 10:40 AM | #1 |
8
Rep 35
replace factory strut or kw v4
In a previous thread I posted that I took my car in for a 6k oil change.
The dealer informed me the front strut is leaking. They denied the warranty b/c the the car was lowered. I lowered the car with h&r m550i springs. A few options: -Dealer can replace the strut for 2300, 2 year warranty. -The shop who installed the springs can replace for 1800, no warranty. They are suggesting to replace with coilover/strut as factory struts will not hold and leak again. -Replace with kw v4 for 6500-7000 There does not appear to be an aftermarket strut option. I checked Bilstein but no love. Any suggestions? |
09-06-2020, 01:25 PM | #2 |
122
Rep 293
Wow V4 is quite pricy, not sure of its advantage over the V3 other than the additional highspeed compression adjustment. Maybe MCS can make dampers for you along with providing the right spring rate for your needs.
09-06-2020, 02:42 PM | #3 | |
4140
Rep 7,159
Drives: F90 M5 / F15 50i
Edit: found a couple on eBay for $600
'07 Yamaha R1 (sold)
09-06-2020, 04:49 PM | #4 |
4062
Rep 5,231
Replace the factory strut .. you should be fine with aftermarket springs and OEM struts.
I've run aftermarket springs on several M5's including my current F90 M5C w/ zero issues.
09-07-2020, 11:43 AM | #5 |
2269
Rep 3,293
My 2 cents....I replacedthe stock set up in my '03 RS6, after they replaced the factory system twice, with the KW V3 setup. I did it myself and it was rock stable for another 75,000 miles or so. Excellent quality parts. At that time the price was $2800, plus the two new roll bars, and a few special tools. It was worth it.
Mike
09-29-2020, 03:56 PM | #6 | |
15
Rep 172
