08-25-2020, 07:25 PM | #69 | |
1316
Rep 2,349
or https://demanddetroit.com/engines/dd16/ (probably not) Can the current Garrett tech work both ways? The name sounds like it might be able to (instead of a wastegate???) then be used to spool the turbo back up again
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
08-25-2020, 07:30 PM | #70 | ||
Plenipotentiary
2614
Rep 3,046
Holset272.50 |
08-25-2020, 07:40 PM | #71 | |
Ring Leader of G8X Haters
25076
Rep 8,762
I Wonder if it will be similar to the system in my CLS which uses an electric supercharger that runs off the 48-volt mild-hybrid system. Its awesome technology, gives the engine incredibly smooth output (almost NA-like), and provides plenty of power before the turbo is finished spooling, and even makes start stop so seamless I never have to turn it off. I love this tech in my CLS and would love to see BMW adopt it.
This instagram post by Jason Cammisa better explains the awesome technology Quote:
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
08-25-2020, 07:46 PM | #72 |
1316
Rep 2,349
https://cdn.borgwarner.com/docs/defa...sn=93bccf3c_19
Electric motor can assist the turbine to provide supplemental boost air to the engine Electric motor (generator) can be driven by excess turbine energy from the exhaust flow Exciting
BMWGirlFL6266.50 |
08-25-2020, 08:10 PM | #73 |
74
Rep 109
In the video sounds like 4 cylinder. Exhaust doesn't look like it's routed from the front engine. Kidney grill shut indicates less cooling requirement, all pointing to a 4 cylinder with some hybrid tech.
08-25-2020, 08:33 PM | #74 | |
6267
Rep 2,351
Drives: Z4 M40i
08-25-2020, 09:28 PM | #75 |
1294
Rep 843
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
Really interested to see what this is, haven't been intrigued by a BMW test mule in a while.
Ibiza3599.00 |
08-25-2020, 10:35 PM | #77 |
3599
Rep 2,858
Something else is up, the engine if it's a P58 sounded great!
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
TrentMeister2854.00 |
08-26-2020, 05:34 AM | #80 |
1429
Rep 1,522
A PHEV with a 4-cyl TERS combined to ~500hp would make perfect sense! Upcoming Mercedes C AMG will presumably also get this configuration!
https://mercedes-world.com/c-class/m...ic-4-cylinders |
JustChris17483.00 |
08-26-2020, 05:36 AM | #81 | ||
1712
Rep 5,109
It definitely sounds like a straight six in the video that I posted on the previous page (listen with headphones to get the best sound). The info provided so far points towards a anniversary special limited edition model that has a P58 engine with MGU-H and possibly MGU-K (to use F1 lingo) and a transaxle. The CSL hommage is a pointer as to what kind of car this will be (hopefully). Oh, and the Batmobile celebrates 50 years in 2023 btw... This article on the CSL hommage also gives som hints as to why the mule has the air ducts in the rear side windows: https://www.carmagazine.co.uk/car-re...e-2015-review/ Quote:
The whole video is worth seeing, but skip to the 13:00 mark to hear what he says about production possibilities Last edited by Boss330; 08-26-2020 at 05:46 AM.. |
08-26-2020, 06:30 AM | #82 |
1429
Rep 1,522
Apparently, it's none of the above. It's just a test mule used to test all kind of new technologies.
Source: auto motor und sport: Bei dem Erlkönig-Modell handelt es sich – wie schon vermutet – um einen Entwicklungsträger, mit dem unterschiedliche Abteilungen des Konzerns neue Komponenten testen. Das kann von Fahrwerkselementen, Reifen, Bremsen, Motor-Neuentwicklungen, Abgas-Komponenten bis hin zur Multimedia-Technik alles sein. In diesem Fall hat BMW einen M8 als Träger verwendet. Also BMW denied working on any config with central mounted engine. |
stein_325i25076.00 |
08-26-2020, 07:12 AM | #83 | |
1712
Rep 5,109
It's not mid engined (that was debunked early on in this thread) but it's most likely a test mule for the upcoming (hopefully) CSL Hommage drivetrain etc. Front engine, straight six, hybrid tech, possibly transaxle. |
08-26-2020, 07:47 AM | #84 | |
6267
Rep 2,351
Drives: Z4 M40i
JTO245271.50 |
08-26-2020, 08:50 AM | #85 | ||
Plenipotentiary
2614
Rep 3,046
08-26-2020, 12:26 PM | #87 | |
1708
Rep 2,539
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
08-26-2020, 01:25 PM | #88 |
2480
Rep 2,335
