08-21-2019, 04:00 PM | #1 |
689
Rep 6,854
▀▄▀▄ Vivid Racing | KW Suspension H.A.S. BMW M5 F90 2018+
Vivid Racing Presents: KW Suspension H.A.S. BMW M5 F90 2018+ Contact Me Directly for Exclusive Forum Pricing! chrisk@vividracing.com | +1.480.966.3040 x226 | www.vividracing.com KW height adjustable spring kits are a great alternative to conventional lowering springs. You now longer have to be satisfied with a fixed lowering height. KW HAS systems allow you to adjust the vehicle ride height with the KW height adjuster even after the kit has been installed. Your vehicle does not only get a more dynamic look with the KW height adjustable spring kit, but also the steering behavior and response of the standard dampers become more agile. All driver assistance systems and comfort features of a factory adaptive or electronic suspension remain operational and work harmoniously with our vehicle-specific spring set up. KW uses high-quality springs made of chrome-silicon steel with spring rates designed specifically for each respective OE suspension damper and wheel load. KW's expertise and engineering ensure the spring rates will pair perfectly with the different damper characteristics of your factory adaptive electronic suspension. Along with the use of high-quality materials and the included KW ride height adjustment mechanisms, our KW height adjustable spring kits always includes the vehicle-specific bump stops with dust protection system to protect your factory suspension against wear & tear caused by road grime and debris. Similar to a coilover suspension, the KW height adjustable springs allow a continuously adjustable ride height within a tested range, something not possible with conventional lowering springs. The dust protection elements and spring perches included in the delivery, when applicable, are always adjusted to the maximum technically possible lowering, typically limited by the factory dampers. With KW height adjustable springs, a sporty and harmonious driving behavior can be achieved without the driving dynamics of performance-oriented vehicles suffering. Features: Lowering Adjustment Ranges: Front: - 5-20mm - 0.2-0.8 Inches Rear: - 5-20mm - 0.2-0.8 Inches Last edited by vividracing; 02-19-2020 at 12:35 PM.. |
05-08-2020, 01:23 PM | #2 |
689
Rep 6,854
Want the EDC function and an adjustable ride height? KW has you covered. Get the best of both worlds with a simple upgrade like adjustable springs!
-Chris
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
09-03-2020, 08:46 PM | #3 |
689
Rep 6,854
This is one of the best first mods for a new car that can transform it. Keep your EDC function and get a great look in the process!
Travis Williams
09-23-2020, 08:46 PM | #4 |
689
Rep 6,854
Quick and easy job along with an ECU tune to have show AND go !
Travis Williams
02-16-2022, 04:27 PM | #7 |
689
Rep 6,854
Just got a few more sets in for the F90. Height adjustable and keep the electronic dampening
Travis Williams
