04-17-2024, 10:15 AM | #1 |
596
Rep 993
Is there a oil filter housing gasket DIY?
Im going to be doing the valve cover gasket and thought i might do the oil filter housing gaskets at the same time. Has anyone done it? Must i follow the instructions in ISTA or can some steps be bypassed like intake manifold removal and draining coolant etc...
FCP sells a kit for $160 but you dont need to replace bolts, oil pressure sensor, or thermostat housing plugs. Any input would be great. |
04-21-2024, 03:07 PM | #2 |
Straight Edge
50
Rep 197
Also interested… I’ll be doing this soon (already have the parts) but couldn’t find any F8x specific DIY.
I did this on my N52 a long time ago and the process should be identical, but the S55 has some additional lines in the way. It may also need the oil system primed afterwards as required on the N55. Here’s the only vid I found for the S55: https://youtu.be/tlKRn2aTJ1I
2015 F80 M3 - Black Sapphire
2012 E92 M3 - Frozen Silver Previous: 2013 F10 M5 / 2011 E92 M3 / 2009 E92 328i |
04-22-2024, 06:05 AM | #3 |
596
Rep 993
Yes, saw that video too. He only loosened the intake manifold. I guess there might not be any shortcuts for this one.
If I'm loosening/removing the intake manifold, I'm gonna replace the gaskets with new ones. Don't want to risk any leaks. I might as well replace belts and tensioner pullies while I'm in there too. |
