04-17-2022, 12:00 AM | #1 |
4154
Rep 3,705
Drives: 2022 M5C
Hello All,
After reading through the technical training manual posted for the F90, I went through F90 LCI training manual to "tie me over" a bit until my new LCI arrives. In reading the materials that highlight the differences between the pre-LCI and LCI, I noticed something interesting in the Infotainment section (photos attached below). The LCI model's documents show a component simply labeled as "Booster." The description states, "[t]he booster is used in the F90 LCI and is an additional audio amplifier in the vehicle." I cannot find the same component in the pre-LCI. I believe this component only exists on LCI models with HK audio. I, like many of you, had to give up BW audio on my incoming car if I wanted to see it in this lifetime, and am stuck with HK (again). So my long wind up brings me to my question…Is there an additional amplifier for HK on the LCI that pre-LCI did not have? Has anyone owned both a pre-LCI and LCI with HK audio? Did your LCI HK sound better than your pre-LCI? Does anyone know if the LCI has an additional amplifier? For what it's worth, it seems that specs show the HK as a 600 watt system on both models. P.S. Before anyone lays in to me, the technical training document referenced in the attached source is simply for the 2018 Infotainment system, and it DOES show a "Booster" as well, but doesn't show the amplifier (which makes me think they've labeled the amplifier in the pre-LCI as the booster), but that could be because it's part of the mid-RAM. The material that the source below references is also not model specific to the F90, pre-LCI or otherwise, and seems to be just about the Infotainment 2018 system generally. Trying to figure out/set up a solution for the audio system on my new car other than BavSound (which I'll save for another post on another day). Thanks in advance for any input!
Not a BMW guy...but certainly an M5 guy.
04-19-2022, 09:18 AM | #2 |
101
Rep 186
Hmmmm that’s and interesting question with respect to the bulletin. I can say that there’s a large difference between the HK in my F10 and the one in my F90
04-19-2022, 11:53 AM | #3 | |
4154
Rep 3,705
Drives: 2022 M5C
EDIT - Just saw from another thread of yours that yours is an LCI. I see you also seem dissatisfied with the HK.
04-19-2022, 09:32 PM | #4 |
101
Rep 186
I wouldn’t say I’m dissatisfied with the H&K in the LCI. One in F10 was horrible. I coded the B&W sound profiles in last night and that helped me tweak the tune a bit more. Doesn’t sound as good as the B&W in the X7 M50i but it’s sufficient. The MPE exhaust also makes it easier to live with as well
04-19-2022, 09:47 PM | #5 | |
4154
Rep 3,705
Drives: 2022 M5C
Thank you!
04-20-2022, 05:28 AM | #6 | |
Rep 25
Drives: BMW M5 Competition
04-20-2022, 11:31 AM | #7 | ||
4154
Rep 3,705
Drives: 2022 M5C
https://www.manualslib.com/manual/19...ci.html#manual
Today, 02:21 PM | #9 |
106
Rep 203
Wow, I've been looking for an LCI Complete Vehicle Guide. Thank you!!!
2021 F90 M5 Competition mods: M-performance trunk spoiler, IND side skirts and front splitter.
335i Manual Swap Project http://www.e90post.com/forums/showthread.php?t=1207505 |
