03-03-2017, 10:11 AM | #221 |
83
Rep 353
Hi,
There is a lot of threads out there regarding the 8S4 and 5AP. I am trying to understand what I can achieve through coding. So I have a 2015 640iX GC US Spec with July 2014 production date. I do have among other options the following 5AC, 5AS, 5DL, 552, 8TH, 8S4. So first question I have the 8S4 (because it is a US Spec car and due to the US DOT regulation) which from what I read disable the VLD (Variable light distribution) all I need to do is remove it and VO code FRM module. Someone correct me if I am wrong. Also do I have hardware limitation or this is just strictly coding and I am off to have the VLD feature. Second question I do not have 5AP as an option, what does it mean can I have the anti-dazzle option? but I read that I don't have the European lights so definitely seems like it is a hardware limitation. Or do I do some FDL coding and I should have that feature. So if someone buys the Euro spec headlights and I swap the US spec headlight is that all or there are also modules that need to be replaced or added. I mean are they direct fitment or its more complicated Can anyone give me insight and clarification on this matter Thank you RB
15 F06 640i xDrive Gran Coupe/Grey
03-03-2017, 11:54 AM | #222 | |
725
Rep 1,615
03-03-2017, 01:10 PM | #223 | ||
355
Rep 1,986
If you do not have 524 and 5AC, it will not work unless both those are retrofitted. If you remove 5AP and /or 8S4 and recode without replacing headlight assembly, VLD will attempt to work without the proper pieces in place, so you will end up blinding the other drivers. |
jeffc83725.00 |
03-03-2017, 01:28 PM | #224 | |||
83
Rep 353
03-03-2017, 03:25 PM | #226 |
284
Rep 703
You can enable VLD but not anti-dazzle. For anti-dazzle/glare you will need new hardware.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
Kabrich355.00 AndrewC198910941.50 |
03-17-2017, 01:57 PM | #227 | |
46
Rep 159
I just got my car serviced (just regular oil change) at the dealer and I asked them to check if new lights are aligned correctly. I tried to align them against carage door but obviously that is not very scientific method to do it. I have my doubts because they doesn't seem to work too well on oncoming traffic. Indeed, they were misaligned both vertically and horizontally. Just wen't for a test drive and now they are working much better! So I would recommend anyone who does this retrofit to check that your lights are aligned correctly. Should come without saying but anyway. |
03-17-2017, 04:55 PM | #229 |
355
Rep 1,986
03-17-2017, 04:58 PM | #230 |
83
Rep 353
03-18-2017, 12:11 AM | #231 |
284
Rep 703
Your not blinding other drivers if you just code VLD. You just can't code ant-glare/dazzle without blinding others. I have VLD coded also with no issue of blinding others.
Variable Light Distribution has several different modes of operation (for Low Beam): 1 - City Light: Shallow and Very Wide Beam Pattern active from 0 - 50kph (30MPH) (Both Headlamps are Panned outwards 12 horizontal from center and 0.7 lowered vertically) 2 - Standard Light: Same Basic Beam Pattern as with 8S4 Enabled and Headlamp Switch Set to Auto. Active from 50 - 110kph (30MPH - 68MPH) 3 - Guiding Fog Light - Shallow and Wider Beam Pattern Enabled with the Front Fog Lamps On and Headlamp Switch in Auto and Speed 0 - 110kph (Both headlamps are panned outwards 8 horizontal from center and lowered 0.7 vertically) 4 - Highway Light - Long Throw Pattern illuminating approx. 25% further than Standard Light. Active from 110 to 250kph (68MPH- 155MHP). (Driver's Side Headlamp is panned 3.5 outwards Horizontal from center and lowered 0.25 vertically, while the passenger side headlamp is raised 0.2 vertical) (thank you @shawnsheridan) Clarification of VLD, HBA, and Anti-Glare/Anti-Dazzle (thank you @skalberti): VLD is Variable Light Distribution - It only works on your low beams to move your headlights and position the beams on the road depending on steering angle and vehicle speed. HBA is High Beam Assistant - USA spec high beams that turn off in the presence of headlights or taillights of other cars and automatically turns the high beams on if no other cars are present. Anti-Glare, Anti-Dazzle - European spec high beams that enable your car to keep the high beams on without blinding other cars.
03-20-2017, 11:29 AM | #232 | |
83
Rep 353
So there is no hardware limitation for enabbing VLD once I took off 8S4 I pretty much have what you described. Not for anti glare there is hardware limitation.....to get the true function I will need a European spec headlights.
03-20-2017, 12:50 PM | #233 | |
284
Rep 703
03-21-2017, 01:17 AM | #234 |
2374
Rep 8,364
Pre-LCI 6-series do have a hardware limitation, even if 8S4 is present in FA.
03-21-2017, 04:07 AM | #235 | |
83
Rep 353
I looked at the headlight part numbers on www.realoem.com and indeed the European headlight has a different part number than a US one. I still took of 8S4 anyway and VO coded FRM. Maybe if one day I find a European headlight I can swap
10-27-2017, 08:11 PM | #236 |
175
Rep 742
I just finished the HBA retrofit using EDM dynamic xenon headlights (I actually started this last year but just got the cluster switch).
Whats the difference between highway mode vs non highway mode? I change the C_HBA_ENA lo and high speed to something lower and it works, HB on or off. Does the highway mode start the tunneling? Thanks!
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
01-23-2018, 12:45 PM | #237 | |
10942
Rep 4,552
Drives: 2015 328d xDrive
(I have a 2er with adaptive xenons) |
01-23-2018, 12:57 PM | #238 |
45
Rep 235
Drives: 2014 F31
At around 33 MPH, the headlight beam pattern will narrow. When your speed drops below 24 MPH (if I remember correctly), the beam pattern will widen. It's easier to see this when it's dark and when the road surface is dry.
01-23-2018, 01:19 PM | #239 |
10942
Rep 4,552
No quick way to check in the garage though? I just want to make sure the coding was successful.
01-23-2018, 01:21 PM | #240 |
2374
Rep 8,364
01-23-2018, 01:23 PM | #241 |
10942
Rep 4,552
01-23-2018, 01:31 PM | #242 |
45
Rep 235
Drives: 2014 F31
I have mine configured for so long so I can't even remember how it used to react before enabling VLD. If you have fog lamp, with VLD enabled, I believe turn on/off the fog lamps will cause the headlights to move from side to side.
