04-11-2024, 06:45 AM | #1 |
2422
Rep 1,770
Drives: Bmw 330i and Bmw 328i
Z4 M54
Hi guys, its almost summer in california and is it okay to use a 20 coolant / 80 distilled water mix?
04-11-2024, 11:10 AM | #2 |
97
Rep 415
No… use the proper ratio. What your are proposing will lower the temperature at which the car coolant will begin to boil over…… the opposition of which you think you are going to accomplish.
Sent from my smart phone...
2one3E902422.00 |
04-13-2024, 11:57 PM | #3 |
Rep 7
If your topping up with that, you'll be fine. Tap water is fine too, adding coolant for a top up is overkill.
If you're performing a drain and fill 80/20 is probably okay depending on how much coolant you have on hand. I wouldn't worry about it too much water under pressure has good heat capacitance. The heater core hoses and o-rings take a beating in the summer if you run the air conditioning in traffic. Last edited by itsjustascratch21; 04-14-2024 at 01:23 AM.. |
2one3E902422.00 |
04-14-2024, 03:47 PM | #5 | |
886
Rep 2,552
Drives: Z4MC-X3-35i-525i, Corrado G60
Use a 50/50 mix of coolant/distilled water, no matter where you live, no matter the time of the year. There's way more properties to antifreeze than simply preventing freezing, fact... |
Aloyouis210.00 |
