F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > DCT shifter on F30 request
ARMA SPEED
      07-08-2017, 07:59 PM   #23
awmenard
142
Drives: 2012 320i
Originally Posted by CaboM4 View Post
Originally Posted by roll_the_dice View Post
If you are stopped in the F30 and before pressing the Park button, turn the car off instead, it will automatically go into park. Maybe this would allow the DCT shifter to work?
+1 ... my thoughts as well
can someone with a standard ZF trans try this? I wont be near my F34 for a few weeks
I tried today, car was in drive, pulled the ebrake, turned car off and it went into Park.
Hope this helps
      07-08-2017, 09:59 PM   #24
roll_the_dice
roll_the_dice's Avatar
508
Drives: 2013 BMW F30 EBII
Hope this helps
You don't even have to pull the ebrake...with foot on the brake, just turn the car off and it goes into park automatically.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread
      07-08-2017, 10:02 PM   #25
awmenard
142
Drives: 2012 320i
Hope this helps
Haaa, I was just going off what was said in the post.
Not sure how come people that have done it can?t share then info.
It would make it so much easier
      11-02-2017, 11:52 AM   #26
edfsanchez24
Drives: BMW 328i M Sport
      11-02-2017, 02:37 PM   #27
kabrichx
Drives: BMW
Correct. I use this method 99% of the time. Have almost never used “Park” button in years of BMW Ownership.
Originally Posted by Jdmdc5teg06 View Post
Hello everyone, I saw a thread earlier where some dude in China retrofitted the F80 DCT shifter on his F30 but all he said was that "coding was required" when asked how he had it retrofitted.
I know those shifters don't come with the 'park' button but maybe there's a way to tap into the lower button on the shifter itself? Maybe a retrofit plug for the park button can be done?
This is the shifter I saw and it has that button in the bottom that maybe we can figure out to tap into to make the park button work. Or am I completely wrong lol
What does the 330e use the button for?
      11-13-2017, 11:09 AM   #28
roll_the_dice
508
Anyone tried this swap yet? I can't find a DCT shifter for sale...
My Build Thread
      11-13-2017, 12:56 PM   #29
kabrichx
Drives: BMW
https://rover.ebay.com/rover/0/0/0?m...2F181711547605
https://rover.ebay.com/rover/0/0/0?m...2F152506949302
https://rover.ebay.com/rover/0/0/0?m...2F272895234938
Look closely at images in first link and you can see section of shifter frame that would need removal/modification to fit in F3x/F4x center console, though it appears it could most likely be cut off on both sides.
      11-26-2017, 04:31 AM   #30
erik_m3g80
erik_m3g80's Avatar
36
Drives: BMW G80 Competition
And somebody have more informations yet? Did somebody try it? Is it Plug n Play except the P Button? Is the Cable Connection the same? Any Coding require?
      12-18-2017, 12:52 AM   #31
icbmwsnpdx
Drives: '13 F30, '01 E46, '83 E21
I was able to find a DCT shifter for under a 100 bucks so I gave this a try on my 2013 BMW 328I N20 Sport.
It works!!
Im able to shift into all gears. I can get park when in drive by pressing the Start/Stop button.
But there is only one issue. At startup or at a full stop the message "Not possible to change gear position" appears.
Seems some coding will be the next step.
      12-18-2017, 06:29 AM   #32
fortythirtyfive
United Kingdom
644
Drives: 435i MS
I might be being dumb here, but surely can't you just split open the pre-existing shifter and follow the circuit for the park button, then wire it up the same as to the gearbox button on the DCT shifter? My only worry would be matching the functionality of the different modes (manual, reverse, neutral etc)
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      12-19-2017, 06:30 AM   #33
Dfahmy
Egypt
140
Drives: F30 335i PWG
2013 BMW 335i  [0.00]
It works!!
So the issue is just with the error message?
      12-19-2017, 04:18 PM   #34
fmonteiro444
fmonteiro444's Avatar
Drives: 23 M3 Competition
I'm seriously debating on doing this. I can't stand the F30 shifter.
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock
      12-20-2017, 12:34 AM   #35
icbmwsnpdx
Correct, just the warning messages. I think the main issue is the unlock button on the stock shifter missing on the DCT shifter. But stepping on the brake unlocks the DCT shifter from park.
Maybe if just the FEM was coded to DTC, and not the ICM or the KOMBI then it would ignore the missing unlock button and suppress the message.
Any ESYS experts out there? I love the feel and way this DCT shifts.
      12-20-2017, 12:38 AM   #36
Dfahmy
Egypt
140
[IMG]http://i1041.photobucket.com/albums/...IMG_1311_1.jpg[/IMG]
Ok any issues switching from drive to reverse and vice versa since there is no unlock button ?
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
      12-20-2017, 04:56 PM   #37
icbmwsnpdx
Zero problems but the error message. Shifter fully unlocks once the car is on and the brake is pressed.
      12-29-2017, 12:30 AM   #38
IK6SPEED
Drives: BMW M3 / AH3
Obviously you have never opened up a BMW Shifter.
      01-11-2018, 07:12 PM   #39
Stlthnmrdrd
1-800-STOCKAF
Drives: G30 520i (Stock)
Does the DCT need to be from a F chassis or can it be any?
F30 320i Stock
      01-11-2018, 11:16 PM   #40
IK6SPEED
You need to be more precise than that unless you are planning to do major surgery.
      01-12-2018, 03:27 PM   #41
Kailec
Kailec's Avatar
595
Drives: 2013 328i xDrive
I saw this and thought you were posting a food recipe for the shifter.. lol
      01-12-2018, 11:28 PM   #42
Dfahmy
Egypt
140
would the shifter from an E9x or E6x M car work by any chance? As they are much cheaper on eBay
      01-12-2018, 11:32 PM   #43
IK6SPEED
Doing nothing is also cheaper.
      01-17-2018, 05:13 PM   #44
icbmwsnpdx
Has to be from an F Chassis or it wont mount correctly also the Clutch adjust button is located on the trim in a F chassis and on the shifter in a E chassis.
f30post
