04-08-2024, 06:56 AM | #1 |
610
Rep 749
Front mount intake cabin sound
I love the sound clips from the outside, but curious to hear from folks about how they compare to engine mounted inside cabin?
Debating myself between RK Tunes, MSR front mount / Eventuri, MAD engine mount. Currently running MPE, secondary DPs, Dinan Inlets, BMC drop in filter. |
04-16-2024, 09:31 AM | #4 |
279
Rep 655
In my opinion I don’t think aftermarket open filters are good for the turbos and engine longevity especially if they are mounted inside the grill exposed to the outher elements.
The ones that installs inside the stock airboxes dont filtrate as good as the stock ones either. But i would not be that concerned if you don’t drive the car alot and just use it more like a enthusiasts car. Sure they sound more but performance wise i read that they don’t make any difference atleast at moderate power increases. The stock airboxes and filters are good filtration and power wise. Just a thing to think about but everone are free to modify their car as they want. |
GranitM5366.00 |
04-16-2024, 11:10 AM | #5 | |
Joint Chiefs of Staff
24463
Rep 191,414
I have not seen any evidence to support your claim, do you have any data you can share comparing the two?
335xiE9016.50 |
04-16-2024, 11:22 AM | #6 | |
279
Rep 655
I can only imagine what that does to insides of the engine. Of course it can play a big role how often you clean and oil the filters but they are generally more open in their design that simply let in more dirt. |
04-25-2024, 04:05 PM | #7 |
279
Rep 655
I appreciate that companys makes aftermarket intakes and other stuff for our cars.
But the truth is performance/power wise the stock intakes are very good on our cars. For example Dme tuning in the Uk have a F90 M5 with stock intakes running 3,7 sec 100-200km/h thats like a low 4 sec 60-130mph that takes some pretty serious power to do so. |
04-26-2024, 12:32 PM | #8 | |
24463
Rep 191,414
With that said, regardless of your setup, the power is still minimal; that's why we never consider the intake upgrade as a mandatory upgrade for power.
04-26-2024, 05:36 PM | #9 | |
2020
Rep 5,083
Most parts are made for their intended use case with a little extra wiggle room on top. Designing a part that can handle up to 1000 is likely not to be as efficient if its only going to be used for 600 hp. You also have emissions stuff added in there yadda yadda. Guess the real question is would it get a better time from adding intakes? Stock intakes flow every well but could they flow better? Yes of course.
04-26-2024, 05:49 PM | #10 |
5287
Rep 10,682
Dinan may be that the only company selling intakes that has actually done flow testing. Their results are available for anyone to see. Probably some of the aftermarket intakes also improve flow, and as Dinan explains, improved flow increases efficiency and that can translate to more power. https://www.dinancars.com/products/i...arts/D760-0049
You can also just add octane and increase boost. At done point the stock parts will become less efficient but you can still make more power. |
04-27-2024, 02:18 AM | #11 | |||
279
Rep 655
