06-27-2023, 02:47 PM | #1 |
Rep 16
Drives: 330 D F 30 and F90 M5
S63 pre and post lci
Hello. I juts bought a 09/22 LCI M5.
I would be interested in the differences in the S63 engine after LCI. - Lower cooling temp. - Higher injectors pressure? - ... Thanks for your feedback. |
06-27-2023, 04:51 PM | #2 |
582
Rep 575
Drives: 2022 M5 CS & 2022 X5M
Pretty sure there are no changes.
06-27-2023, 06:56 PM | #3 |
983
Rep 1,798
There were some changes but not power related. The information is in other post of you are interested.
06-28-2023, 09:00 AM | #4 |
Rep 16
06-29-2023, 07:47 PM | #5 |
72
Rep 164
Coolant hose routing seems to be the only thing I know for a fact is different
07-05-2023, 04:29 AM | #6 |
Rep 15
Different downpipes for EU models
https://f90.bimmerpost.com/forums/sh....php?t=1978697 |
11-18-2023, 02:32 PM | #8 |
36
Rep 151
11-25-2023, 02:54 AM | #9 |
Rep 16
11-28-2023, 03:00 PM | #10 |
Rep 17
I was told that the LCI motors use a sprayed bore liner because the alloy of the block is less durable; came up in convo with a tuner when deciding if I should build my current pre-LCI or trade up to an LCI to do the build. Not started the build yet, but if I do I will definitely stick with what I've got, for multiple reasons.
