04-29-2024, 05:46 PM | #1 |
Your Average B58'er
290
Rep 240
Paragon P3 Brake Pads
Received partial delivery of my new P3 pads and rotors.
Let's play a game of "can you spot it" and see if someone can spot a difference in these 4 pads? 2 are still in the wrapper and the other 2 are loose. Good luck! 😁
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
04-29-2024, 06:44 PM | #2 |
3377
Rep 1,829
Drives: 2022 X3 M40i
It's fine...only one inboard pad on drivers front uses 1 sensor and one sensor for inboard pad on passenger rear.
04-29-2024, 06:56 PM | #3 | |
Your Average B58'er
290
Rep 240
Yeah I understand that part. What concerns me is the notch area where the pad is looking brittle. Seems like they manufactured the backing plate in the wrong orientation. After the pad wears down, that part of the pad may be susceptible to further damage due to uneven distribution of pressure? What do you think?
04-29-2024, 09:09 PM | #4 | |
3377
Rep 1,829
Also this pad compound is aggressive but durable from what I understand, lol the wear with the paragon grooved rotors will always cut an even face on the pad under hard braking..it shouldn't be "brittle" where chuncks will come off. Or I am talking out of my ass and not sure I understand what your asking,.....lol Last edited by Burr001; 04-29-2024 at 09:23 PM.. |
04-29-2024, 09:26 PM | #5 | |
Your Average B58'er
290
Rep 240
More so the possibility that the pad bridging over the notch area would become a weak point under heat, vibration, pressure. Regardless of it all, I payed for it and currently in email contact to get a correctly made product replacement. Don't really feel like being a guinea pig for bad QA, especially on a piece that my life could depend on lol Now we'll see if their customer service can exceed their product reputation. I have received only 1 email reply to the situation so far acknowledging that it is pressed on the wrong side of the backing plate.
04-29-2024, 09:58 PM | #6 | |
3377
Rep 1,829
04-30-2024, 03:47 AM | #7 |
Your Average B58'er
290
Rep 240
Hot damn!...here I am thinking were talking about the same issue and maybe I'm just overreacting 🤣
04-30-2024, 08:20 PM | #8 |
3377
Rep 1,829
FYI rotors are the same with GR Supra.
Gr8ZongB58290.00 |
