12-06-2021, 09:44 AM | #89 | |
87
Rep 280
12-06-2021, 11:10 AM | #90 | |
180
Rep 374
Andre OFV90.00 |
12-06-2021, 11:50 AM | #91 | |
146
Rep 140
Drives: G01M40, F82COMP
kenrok154.50 |
12-06-2021, 01:03 PM | #92 | |
55
Rep 80
Drives: 2022 X3 M40i (two)
Last edited by kenrok1; 12-17-2021 at 03:45 PM.. Reason: remove comment about it being gone, still there... just moved and I didnt see it strait away, but it still doesnt do anything |
12-06-2021, 05:13 PM | #94 |
2779
Rep 4,353
12-07-2021, 07:26 AM | #96 |
18
Rep 44
I just got my 2022 X3 a few months ago and half the time I drive it, my phone keeps disconnecting and reconnecting every 10-15 seconds to the point where I just disconnect entirely and don't use apple CarPlay or my music. I took it to the dealership and they basically just advised me to run the latest software on my phone and reset the head unit. This seemed to fix it for a day but then it was back to usual. I'm so frustrated with this but I don't know what else I can do. Is anyone having this issue? Is there anything I can do to help prevent it from disconnecting?
12-07-2021, 08:51 AM | #97 |
How YOU Doin?
1710
Rep 1,558
Drives: 2022 BMW X3 M40i
Carplay connects to your phone via wifi. Are you using the wifi on your phone for any other purpose?
bimmerbabe9718.00 |
12-07-2021, 09:01 AM | #98 |
18
Rep 44
12-07-2021, 09:04 AM | #99 |
2779
Rep 4,353
12-07-2021, 09:05 AM | #100 | |
How YOU Doin?
1710
Rep 1,558
If that's not the case, then there might be something else going on. Just wanted to rule that out as a first check.
12-07-2021, 09:06 AM | #101 |
How YOU Doin?
1710
Rep 1,558
You can play music via Bluetooth and/or USB with your phone, but AFAIK, CarPlay itself can only be connected via wifi in the X3/X4. Someone correct me if I am mistaken.
12-07-2021, 09:17 AM | #102 |
1302
Rep 975
This is correct. CarPlay is via WiFi only… USB only charges… even without wifi, I believe Music is thru BT, not the USB. (I guess technically, you could turn off your BT and connect via USB and see if it will still use it as music player… I'm guessing it would).
avi662779.00 |
12-07-2021, 09:26 AM | #103 |
Rep 4
Next dumb question, if I may - using the adaptive cruise control in traffic. When the car in front slows to a stop my car will do the same. When the car in front drives off, it seems to be random whether my car will follow on its own or will wait for me to tap the accelerator.
It doesn't seem to depend on the length of time standing still. Any insights? |
Andre OFV90.00 |
12-07-2021, 10:26 AM | #104 | |
678
Rep 910
BMW connected drive specifically state that Bluetooth and WiFI have to be activated/active for Carplay connections. Bluetooth alone does not have sufficient bandwidth to support the more data hungry apps. |
12-07-2021, 12:00 PM | #105 | |
2779
Rep 4,353
12-07-2021, 12:45 PM | #106 | |
413
Rep 302
12-07-2021, 12:51 PM | #107 | |
413
Rep 302
If the new phone works OK without disconnecting regularly, then the problem seems to be with your phone. Maybe reset it back to factory settings, and set it all up again? |
bimmerbabe9718.00 |
12-07-2021, 12:56 PM | #108 | ||
18
Rep 44
NoMoreVauxhalls412.50 |
12-07-2021, 01:36 PM | #109 |
678
Rep 910
Spotify subscription via connected drive app will work through car internal sim, so no mobile necessary. Internal sim provides data/connection for iDrive apps, S.O.S, concierge system, nav updates etc and if you buy subscription also WiFI hotspot. If you run Spotify via your phone using Carplay or android auto then it will use phone sim for data.
avi662779.00 |
12-07-2021, 03:06 PM | #110 | |||
157
Rep 273
Had to fix it, drove me crazy every time I got in the car. |
Tags |
dumb, questions, silly, stupid |
