BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    1/4mi 60-130 Dragy Tips and Tricks
      09-25-2021, 11:07 AM   #23
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Finally a nice dip into negative DA. Car is asking for a lot of fuel because of the air, trims are tabletopped. I'm at E37 on this run and need to back down in E content and or add meth. I'll be adding meth later this month.
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
      09-25-2021, 11:19 AM   #24
AngryInch
213
Drives: 2021 BMW M5 Comp
Shit man that is good! Proof to my argument with these cars right there… timing is everything! Your hitting great timing through most of the pull and 22 at the top of 5th, with moderate boost. She is definitely moving air with your fuel trims that high. I usually see around 35 maybe 40.
Do you find your timing increases as the da lowers? I’m starting to see that with mine, but I’m not sure if it’s a coincidence or not..
Great runs for no dps and JB4…
What meth system are you buying? I’m ordering one too.. snow performance 2.5 I was looking at?
      09-25-2021, 01:56 PM   #25
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Do you find your timing increases as the da lowers? I'm starting to see that with mine, but I'm not sure if it's a coincidence or not..
What meth system are you buying? I'm ordering one too.. snow performance 2.5 I was looking at?
Yes def bump in timing at Da drops. Thx man I'm really happy with my numbers for such little mods.
Going to use the JB4 meth system for its failsafes.
      09-26-2021, 07:13 AM   #26
brad65ford
257
Drives: 2022 M3
That is same damn good weather conditions and times. Need the weather to change here
      09-26-2021, 07:21 AM   #27
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Thx man, all of my runs are planned relative to weather. Some runs are at 4am lol #DAhunter
      09-26-2021, 09:06 AM   #28
AngryInch
213
Hahahah da hunter, love it. Do you notice your timing doesn’t go as high in worse da or is it always consistent?
      09-26-2021, 11:34 AM   #29
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Hahahah da hunter, love it. Do you notice your timing doesn't go as high in worse da or is it always consistent?
https://datazap.me/u/wadefinehomes/l...=1-4-5-6-11-36
This a log of a run in DA1800ft, looks as if peak timing was about 15deg.
I ran a 7.12 60-130 here.
      09-26-2021, 12:05 PM   #30
AngryInch
213
That is exactly what I am running now low 7s in the teen range like that with 15degree of timing in 5th, a bit higher timing sometimes in 4th.
Maybe it is the DA controlling the timing.. You'd think it would be intake temps, but denser air would cause more combustion pressure, if the octane can handle it. Cooler air is denser... hmmm.. Thanks for sharing, that site is mint!
      09-27-2021, 07:51 AM   #31
Boosted_8
447
Drives: M550i
Watching the weather here in the UK, waiting for it to drop below 50f / 10c and stay dry for the best runs...
      09-27-2021, 11:05 AM   #32
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
You will se a nice bump in power once the temps drop and the air dries out.
It's all "connected" IAT's will drop when overall temp drops, drop in temp will drop DA (along with humidity) As you stated cooler is denser, more oxygen rich, so ECU will advance timing.
Your 60-130 and traps seem to be inline for your mods relative to your DA. A few tweaks and some better air...
      09-27-2021, 11:14 AM   #33
eric97hoh
Drives: 2020 bmw m5
this is wild without dowpipes props man.and that da is nuts
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel
      09-27-2021, 07:05 PM   #34
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Thx my man. I'm going to add secondary downpipes and will keep the primary stock followed by "lightweight" wheels. I'm full carbon fiber roof with carbon ceramic brakes, but I have the heavy cast wheels. I'd like to get my 60-130 in 6.4X range with those mods. We will see.
      09-28-2021, 05:52 AM   #35
eric97hoh
Drives: 2020 bmw m5
I got ceramic brakes with the black wheels but sun roof :/
      09-30-2021, 10:56 PM   #36
SGMM5
SGMM5's Avatar
116
Drives: 2020 M5, 2001 Lexus IS300
2020 Base model w/exec, no sunroof, steel brakes
Dinan inlets
BMC Filters
JB4 Map 1 on 93 oct
Remus exhaust
789m wheels with 285/295 PS4s
Launch control, MDM 4wd, normal tire pressure
Was uphill at the end pretty significantly but this is my best time so far. First draggy since the inlets but also coolest temps I've run in. Temps in the 50's.
Car def loves the cool air.
      10-01-2021, 09:59 AM   #37
AmooManiak
649
Drives: 21 X5 M50i -> M2C -> 21 M5C
I thought for lauch control to engage correctly DSC has to be off. Does it also work with MDM?
      10-01-2021, 09:59 AM   #38
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Dinan inlets
BMC Filters
JB4 Map 1 on 93 oct
Remus exhaust
Wow that's quick!! The newer models 60ft much better. I can't get off the line that quickly. Our MD air is perfect right about now. 👌.
What was your 60-130 on that run?
      10-01-2021, 11:44 AM   #39
SGMM5
SGMM5's Avatar
116
Dinan inlets
BMC Filters
JB4 Map 1 on 93 oct
Remus exhaust
60-130 was 8.02. The end is where I started hitting an uphill so may have impacted the time some. For me I've never had great 60-130 times on 1/4 mile runs.
I'll have to try some dedicated 60-130 and see if it can do better.
      10-01-2021, 01:08 PM   #40
eric97hoh
Drives: 2020 bmw m5
don't even sweat it you cars a heavy spec did 10.4 with map 1 jb4 look at the bright side insane stuff with good da
and no downpipes wow
      10-01-2021, 01:18 PM   #41
eric97hoh
Drives: 2020 bmw m5
also the car lets you launch in mdm mode I thought you had to be in fully dsc off to launch
      10-01-2021, 02:56 PM   #42
AmooManiak
649
Was that a question or an answer? Because that's what I asked above and didn't get an answer. According to all "directions", DSC has to be totally off and transmission set to fastest manual setting (but shifts automatically.)
      10-01-2021, 03:39 PM   #43
AngryInch
213
Awesome run SGM, do you have a JB4 graph log you can post please? 10.34 is my best time so far in really good cold air.
      10-01-2021, 04:06 PM   #44
eric97hoh
Drives: 2020 bmw m5
a question I was trying to ask him how he got it to launch in mdm mode I was under assumption it had to be in fully dsc off mode sorry
