BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Winter set up M5 Comp?
      09-10-2019, 02:29 PM   #1
bear040
59
Drives: M5 Comp
Please help... can't seem to get straight answer from Dealership.. Are winter rims and tires same for 2019 M5 as M5 Comp... dealership says yes. 19 inch... other places say no just 20 inch will fit Comp.... what is correct?? Please help..
      09-10-2019, 03:11 PM   #2
jsf721
Drives: 2019 540i X M Sport
I think it depends on the brakes. Ceramics may have bigger platters and need more caliper clearance. Tire rack should know specs. Check out their site.
      09-10-2019, 03:34 PM   #3
AGS
AGS's Avatar
499
Drives: 2022 M5 Competition
The base M5 and M5 Competition will both take the same wheels - that is to say any wheel that fits one will fit the other. The issue your facing from the "other places" is that not all 19" wheels will fit the M5 due to the size of the brakes, so they are incorrectly telling you that you need 20" wheels. Any OEM 19" wheel can be configured for a winter wheel set on either the base or Competition model. There are also certain aftermarket 19" wheel that will fit the M5 but unless the manufacturer markets them as fitting the M5 you really need to test fit them first before buying.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      09-11-2019, 02:51 AM   #4
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
That's not entirely true. There's only one 19" OEM wheel that will fit the M5 and that's the style 705M wheel.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
      09-11-2019, 07:17 AM   #5
AGS
AGS's Avatar
499
Thanks for catching that. What I meant to say was any 19" OEM M5 wheel will work on both the base and Competition M5. There are two wheels, the standard 705 and the OEM M5 winter wheel (not sure of the code).
      09-11-2019, 07:39 AM   #6
Nikolov
239
The 705M is the OEM M5 winter wheel, it just comes in a different color.
      09-26-2019, 10:58 PM   #7
Willie_Beamen69
Drives: BMW M5 F90
Any one have luck finding winter tires? Looked on tirerack only summers are available.
      09-27-2019, 06:44 AM   #8
Ryno 27
Drives: M5 Competition, X5 M50i
Yes, they have Pirelli Sottozero in stock... OEM 20s spec
      09-27-2019, 08:02 AM   #9
Willie_Beamen69
Drives: BMW M5 F90
Looking for 19"
      09-27-2019, 09:53 AM   #10
kdeleon
94
Drives: M5
Originally Posted by Linsanity88 View Post
Looking for 19"
This is why I went with 20". TR didn't seem to carry any 19" last year. Your best bet might be to go through your BMW dealer.
      09-28-2019, 10:35 AM   #11
2000cs
3491
Drives: Potato
I haven’t found a 19 in winter tire or any 19 or 20 all season tire that meets the specs (load in particular). I would like to have AS on my car right now so I could take a drive across the country, from the warm temps at my home through the snow and cold in the upper Rockies. Not an option.
      09-28-2019, 11:23 AM   #12
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Looking for 19"
Tire Rack has both Michelin and Bridgestone in 19" winters. Look under tires by brand winter/snow. The Alpin PA4 or PA4 N in Michelin will work, or the Blizzak from Bridgestone LM-32.
      10-05-2019, 10:45 AM   #13
wisti
Drives: M5 Comp
This is a picture taken from the pamphlet of my local BMW dealer. I live in Montreal. Prices are in Cdn dollars and a 15% tax needs to be added.
I did not go down that route although I wanted to fit 19's for the winter.
I ordered a set of GTS wheels (510) that I have fitted with Michelin Alpin (265 40 R19). I will never drive with Sottozero's again… ever ! To my knowledge and following my research, Michel Alpin and Pirelli Sottozero are the only two winter tires available in that size.
I had sent an email to GTS wheel prior to my order. They assured me that the wheels I have ordered do fit the M5 comp. GTS also manufactures the 505 wheel that does fit our vehicle as well.
BTW, the size of the brakes of the M5 and M5 comp is the same. As far as Carbon Ceramic is concerned, I do not know. However, the CC brakes are available on the normal M5. So why would your dealer tell you that 19 inch wheels do not fit on the Comp; only on the normal M5 if it is only a matter of brakes ?
      10-05-2019, 10:48 AM   #14
wisti
Drives: M5 Comp
Here are pics of the GTS wheels I was talking about. The 510's and the 505's.
Will post pics of my car once the tires are on… when winter comes… which could be next week in Montreal !!!
      10-26-2019, 04:08 PM   #15
ActionDH
83
Drives: M5
Winter shoes on, ready for ice dancing
Comp 20" CCB with Michelin Pilot Alpin 4
      10-26-2019, 05:56 PM   #16
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
23 Bmw M3  [10.00]
Question...
On your rear tires, I assume those are directional? Look for an arrow that is pointing to the front of the car.
On the front, it should say outside.... trying to confirm if tirerack messed up my order.
      10-26-2019, 06:06 PM   #17
ActionDH
83
Drives: M5
Question...
Yes, Fronts labeled outside and rears are directional
      10-26-2019, 06:11 PM   #18
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
Thanks... It must be the new norm or at least for the M5(20s) outside of the Scottzeros option vs AP4s
How are they? I've got a set and am going to mount next week. Get yours off Tirerack?
The only reason I ask is the rears are Directional and the front is an Asymmetrical tire design.
      11-02-2019, 09:16 PM   #19
ActionDH
83
Drives: M5
Yes, got them off TireRack, ride is nice, no frozen precip for me yet though to do a full test
      11-03-2019, 05:00 AM   #20
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
Same here, I am going to install next weekend.
      11-05-2019, 05:29 AM   #21
vink
92
Drives: 2019 BMW M5C, 2020 BMW X7 M50i
Why doesn't tirerack show Michellins Alpin PA4 as winter tires for F90 Competition? Instead the only option listed is Pirelli's. But search by tire size shows Michellins. Not sure why!
Search this Thread:
Advanced Search
