BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Winter setup recommendation for F90 M5C
      09-05-2019, 09:41 PM   #1
vitaly
68
Drives: NA
What's the consensus (if there's one) on a good setup for the winter on this car? I have the 789M rims FWIW. It has the MPS4S tires which aren't going to fly in the (even mild) winter, I suspect.
The car is leased and I'm trying to avoid, if possible, dropping ~$3500 on the 19" OEM winter setup. Tire Rack only shows the Pirelli Sottozero Serie II as an option, $1600 shipped (+ whatever dealer will charge for install).
Are there other options? What are people doing? I'd be perfectly fine buying a used OEM winter set but only saw 1 offered recently here for $2800 (and it sold anyway) - at that rate, I'd just buy a brand new set myself (that one had 1k miles and a bit of rash on one of the rims IIRC).
I can also get the OEM set and then try to sell it in 3 years but if the M5 sees a different bolt pattern by then, may not be many buyers.
Suggestions/opinions welcomed. Thanks
      09-06-2019, 04:07 AM   #2
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
You can get Michelins too - Pilot Alpin 4. They have the stock 20" sizes - 275/35/20 and 285/35/20. That's what I plan on using and we get decent amounts of snow here.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
      09-06-2019, 06:13 AM   #3
vitaly
68
Drives: NA
Thanks. Any reason TR doesn't suggest them? Is there some subtle fit issue? Also, are the Alpins considered better than the Sottos?
      09-06-2019, 10:08 AM   #4
CanadianF90M5
125
Drives: 2019 BMW F90 M5
This is what I'll be using in the next 6 to 8 weeks ...
Previous: 2005 BMW E60 545
      09-06-2019, 10:08 AM   #5
Oswiff
Oswiff's Avatar
Drives: 2021 m5 comp
Sent you a PM - have a set to sell.
      09-06-2019, 02:45 PM   #6
Nikolov
239
No idea why TR doesn't offer them. They'll fit without any issues and I'd say they're better than the Pirellis, yeah. I had them on my F10 and the road to my house is pretty steep - didn't have any issues in the winter. They also had exceptional grip in the wet and more than decent grip in the dry.
      09-06-2019, 06:12 PM   #7
vitaly
68
Drives: NA
Thanks, good to know. Looks like TR has them but only in 275/35/20, not 285. Might contact them and see what's up. I'm guessing running a square setup of 275s all around ought to be fine as well?
      09-07-2019, 12:38 PM   #8
stbm5
261
Drives: 2018 M5 DG
i don't get the pirelli hate. I've run the sottozero IIs for 4 winters on m4 and m5 and never been anything but pleased with them.
      09-12-2019, 05:21 AM   #9
vitaly
68
Drives: NA
Slight update: TR does carry the Alpin PA4s in staggered after all.
$377.94 275/35/20
$406.88 285/35/20
They're V rated on all corners - Sottos can be W (or V for slightly cheaper), in both sizes. But I suspect V is plenty for winter driving
      09-14-2019, 02:06 PM   #10
Nikolov
239
I have PA4 on order as well and mine are W rated. V is 149mph / 240kmh so you should be fine.
