BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    KW has kit vs H&R m550i springs
      08-06-2019, 07:17 PM   #1
MpowerMike
MpowerMike's Avatar
360
Drives: 2012 IB BMW M5
When having the KW has kit maxed out on the lowest setting in the front , compared to h&r m550i spring which is lower ?
2018 F90 BMW M5 Marina Bay Blue
2012 F10 BMW M5 Imperial Blue
2006 E60 BMW M5 Indianapolis Red
2006 E65 BMW 750i Titanium Silver
2001 E39 BMW 530i Orient Blue
      08-06-2019, 07:28 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
M550i H&R's are slightly lower on the front than the KW's on the lowest setting.
Just made this change and it's noticeable w/o even taking into account that they will settle lower.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      08-06-2019, 07:55 PM   #3
TrevorM3
3318
Drives: 6.3 AMG
i can answer that question with photos, after saturday, possibly.
      08-06-2019, 09:18 PM   #4
MpowerMike
MpowerMike's Avatar
360
Can you please post some pictures in thread .
      08-06-2019, 09:19 PM   #5
MpowerMike
MpowerMike's Avatar
360
Thx! Please share some pics in this thread when you get a chance.
      08-06-2019, 09:19 PM   #6
josec70
josec70's Avatar
Will take some in the coming days
      08-06-2019, 10:04 PM   #7
MpowerMike
MpowerMike's Avatar
360
Waiting
      08-07-2019, 02:25 PM   #8
Vic55
Vic55's Avatar
18966
Drives: 2023 BMW M8 Competition Coupe
Interesting, I thought KW went 1.5 inches square as you can go lower than the recommended settings while the M550 is 1.3/1.2.
I have seen KW cars that are visibly lower than M550 dropped F90's
2023 BMW M8 Coupe Competition Alpine White
2022 BMW M3 Competition XDrive Aventurine Red
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      08-07-2019, 11:30 PM   #9
josec70
josec70's Avatar
Vic, hope you're well brother.
KW HAS according to their website lowers both front and read .2"-.8".
You can certainly square up the wheel gap all around but not if you want to have the fenders right above the tires. The rears on the KW HAS will allow an aggressive drop where the fender is right over the tire but the fronts don't go as low so the gaps are not uniform or square all around. With that said, the quality of KW is top notch as is the adjustability factor and the quality of the ride (very little rebound).
I've only been on the HR 550 springs for a couple of days and the fronts are lower than the KW HAS, and this is before they've settled completely. Is it perfectly balanced all around, probably not. Is it a huge difference, probably not.
For 99% of people, the KW's are just fine.
Vic5518965.50
      08-08-2019, 09:45 AM   #10
josec70
josec70's Avatar
Here is a pic .... car is on 21" Wheels on 275/295 Mich 4S and H&R M550i springs
soopa113.00
      08-09-2019, 12:37 AM   #11
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
@MpowerMike , regarding what you mentioned in the PM.
I just went through the installation process in my mind and I think I might know the issue here.
There is 2 possibilities, but the first one is my main suspicion.
Possibility #1 - The spring perch on the front shock is not pressed to a proper position or low enough into the shock body.
Possibility #2 - The front and rear spring got swapped. They will fit either way. Just will give you different drop and ride quality.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
March SALES!! Evolution Racewerks - Until 04/01 | PM for DEALS
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      08-10-2019, 10:39 PM   #12
MpowerMike
MpowerMike's Avatar
360
Actually I did what you mentioned in the pm and I’m really happy with the outcome!
r33_RGSport12803.00
      08-10-2019, 11:53 PM   #13
r33_RGSport
Good to hear. Glad I can help.
      08-11-2019, 05:38 AM   #14
josec70
josec70's Avatar
Can you post a pic of the front?
      08-14-2019, 11:10 AM   #15
Vic55
Vic55's Avatar
18966
josec70
Sir please assist here since you have had both KW HAS and now M550.
From lower speeds 0-60 mph on ok roads:
Whats more bouncy in Sport Plus shock setting or are they pretty much the same
From higher speeds 70-130 on ok roads:
Same question- same setting.
And
What has more lean at higher speeds 70 to 130 in turns:
KW or M550.
I ask cause Im about to cave and ditch the F90 H&R's for the M550's. I find the F90's to be a bit bouncy on compression and rebound even on the most normal of streets much like stock. I am hoping to not get worse quality. But damn I love the M550 look.
      08-14-2019, 05:14 PM   #16
josec70
josec70's Avatar
josec70
And
KW or M550.
Vic,
I think in regards to bounciness they are very simliar in both in 0-60 & 70-130.
If I had to pick one, I would say the M550i springs are slightly better in the 0-60 while the KW are better from 70-130.
At high speeds the KW exhibits less body roll and lean, but again, the difference is not drastic. Miami is not an exciting place to drive so 70-130 turns are few and far between.
My decision to go the M550i route was based on looks and some of the positive feedback from other members. I really love the KW HAS but wanted a more aggressive drop on the front.
      08-14-2019, 05:19 PM   #17
Vic55
Vic55's Avatar
18966
Vic,
Well .... I waited and waited for you to post and you took too long so I ordered the M550 springs
Ill post pics as Ben aka r33_RGSport ordered and will do the install this weekend.
And thanks for the input- exactly what I was looking for.
r33_RGSport12803.00
      08-14-2019, 05:45 PM   #18
josec70
josec70's Avatar
Vic,
Yoooo, I knew it was only a matter of time. We're cut from the same mold when it comes to stance ... seen enough pix of your cars to know this.
Sometimes this is the price we pay for being early adopters ....
You'll be VERY happy with your decision.
      08-14-2019, 06:30 PM   #19
Vic55
Vic55's Avatar
18966
I sold my F90 springs already LOL
Maybe its cause I was bored with finally no plans this saturday
r33_RGSport12803.00
      08-14-2019, 08:01 PM   #20
josec70
josec70's Avatar
Hahahaha. Post some pix when done
      08-18-2019, 03:25 AM   #21
EDDYFIG
EDDYFIG's Avatar
304
Drives: F90 M5
So I have 2k miles on my M550 springs and I couldn't be happier !!!
EDDY_FIG ON INSTAGRAM
      08-18-2019, 07:02 AM   #22
soopa
113
Drives: 2018 F90 M5
Looks GREAT! Anymore pictures to share?
Search this Thread:
Advanced Search
