BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Coolant Message
      10-14-2018, 10:46 PM   #1
kdeleon
94
Drives: M5
Coolant Message
I got a low coolant warning this morning. My car is about 5 months old. Just want to ask around here if this is common for this car as my previous car never needed coolant outside of service. Otherwise, I will take it into service to check if there are any leaks.
I had to fill about 25 oz to get it back up to spec.
      10-15-2018, 02:05 AM   #2
dk79
Drives: 2018 F90 M5 Marina bay blue
Mine did that too, I had bmw coolant bottle in garage, needed to dilute it with water 50%. Added coolant good for now. Did not find any leak on my inspection.
      10-15-2018, 02:41 AM   #3
visualguy
183
Drives: M5
Are there multiple coolant reservoirs in this car? Do you need to fill it in more than one location?
      10-15-2018, 03:41 AM   #4
AGS
AGS's Avatar
500
Drives: 2022 M5 Competition
One of my F10 M5s had the same issue. Turned out there was a cracked coolant line that needed to be replaced.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      10-15-2018, 03:42 AM   #5
AGS
AGS's Avatar
500
Yes, there are two separate cooling systems. One for the engine and one for the turbos.
      10-15-2018, 04:18 AM   #6
dk79
I just filled out the main coolant reservoir as it was low.
      10-15-2018, 06:55 AM   #7
kdeleon
94
Drives: M5
Mine was also only the main. The other tank was fine.
      10-15-2018, 10:05 AM   #8
adeuel
316
Drives: 2021 Oxford Green M5C
Coolant expands and contracts just like your tire pressure. Cooler weather may cause a low coolant warning. Just topped mine off last week as well.
Bönz183.50
      10-15-2018, 10:35 AM   #9
GUNGASLOW
192
Drives: 2019 M5
What type of coolant can you use from the auto parts store?
      10-15-2018, 11:02 AM   #10
Bönz
Bönz's Avatar
Drives: 2018 M5
Mine just did it this past weekend when it was cold. Adeuel is correct. The coolant contracts when cold. A little top off is all that's needed.
      10-15-2018, 02:57 PM   #11
dk79
Mine needed 750cc lol not just top off. Buy a bottle of bmw concentrated coolant bottle for 10 bucks from dealership. Dilute 50:50 with water. Had a bottle sitting in garage from previous f10 m5.
      10-15-2018, 03:43 PM   #12
kdeleon
94
Drives: M5
Actually, when you convert to fl oz, that is just about the same amount that I needed. I assume because that is where the sensor kicks in.
And I agree, I had a bottle of BMW coolant that I used on my E46 M3. But I only needed it after it was over 10 years old, closer to 12.
      10-15-2018, 04:27 PM   #13
WasIgoingSideways?
Drives: 2018 M5
I had mine come on when cold at night after picking it up at the airport. Car is 6 mo's old. Drove home and parked in garage. Light did not come on the next morning. Had an oil change scheduled for the next day and they checked it out. Nothing out of the normal and it never came on again.
      11-12-2018, 08:25 PM   #14
ACF90M5
ACF90M5's Avatar
21
Drives: 2018 F90 M5
Just had mine do the same thing today. It got below freezing this weekend and I haven't driven her since Friday afternoon. Hopefully this trend doesn't continue in in the winter. I am due for service in 2300 miles. The service advisor said this is common in newer BMWs.
It is a little odd though because the rest of the day I had some weird startup errors with the driver assist systems showing "permanently off" for about 10 seconds and the digital dash not displaying for the same amount of time. Also my bluetooth would restart my music selection regardless of what the last song was.
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl
      07-15-2019, 06:54 PM   #15
seamasters
seamasters
Australia
29
Drives: M5 F90 COMP , M4 Mineral White
What coolant did you use? And can I use same coolant for both? Or do they have different ones. Like blue and red. I have some genuine bmw blue coolant not sure if i can use it? Both my coolants are less than minimum. 2019 F90 M5 competition.
