Pls Help. Long Crank / Electrical Issues - E90
06-04-2018, 08:12 AM | #23 |
13
Rep 33
Drives: 2006 BMW 330i
Update for anyone still following this thread...
I finally decided to go to a shop, mechanic I've known for a couple years and had work on my past vehicles before I started learning some things. He had it for about 2 hours and hooked up his laptop ran a couple tests and checked for codes and such. His response to the issues was basically... "Every test I ran showed everything was fine, which is a problem because there are so many things it could be and each of them are hundreds of dollars. Your best bet is to keep driving it until the ECU realizes something is wrong and gives you a code or dash light. Otherwise we'd just be swapping expensive parts in and out until it fixes it which isn't smart." I'm also in a nation-wide BMW facebook group were someone with the same year and model vehicle posted about this issue and about 6 people commented saying they had the same issue and it was there starter, however about 2 commented saying their issue was solved by replacing injectors. I'm tempted to do what you guys said and just go buy a new starter and put it in...
- Tempxst
2006 BMW 330I |
06-04-2018, 08:37 AM | #24 | |
17
Rep 328
From what you have described, it sounds more like a fueling issue. At this point, I would lean towards a fuel pump starting to fail, or dirty injectors. If you're willing to load the parts cannon to try to fix your issue, I would start with an OEM fuel pump. |
06-04-2018, 10:58 AM | #25 | |
13
Rep 33
I believe the fuel pressure is dropping after it sits and the cranking is taking so long because its waiting for the pressure to be rebuilt before the engine will start. Is it worth checking the fuel filter on the regulator? Or am I better off just buying a new pump and installing it? ALSO any recommendations on where/which pump is a good replacement. I see some for $70-$450 and I'm not sure of quality.
- Tempxst
2006 BMW 330I |
06-04-2018, 01:52 PM | #26 | |
17
Rep 328
06-05-2018, 09:32 AM | #27 | |
13
Rep 33
I can't hear the pump prime at all, even when taking the back seats off and putting my ear right next to the pump. I think I'm going to order a new regulator this weekend and install it since it's cheaper than a whole new pump assembly. It seems that the pump runs fine after the pressure is built up. Thanks for the information!
- Tempxst
2006 BMW 330I |
06-05-2018, 09:52 AM | #28 |
13
Rep 33
UPDATE:
I just found this other thread that was apparently invisible before. Same car, exact same symptoms, all fixed by replacing FPR. http://www.e90post.com/forums/showthread.php?t=1004917 I'm gonna give it a go this weekend and will update if it fixes my issue! Hope this helps anyone in the future who has the issue.
- Tempxst
2006 BMW 330I |
06-07-2018, 08:10 AM | #29 | |
17
Rep 328
I could be mistaken about when E90s prime the pump. Someone else may be able to chime in. I know some VWs and other Euros prime when you unlock the doors. Glad you found a relative thread to aid you though! A FPR shouldn't break the bank. So it's a good starting point. Good luck. Keep us updated. |
06-07-2018, 08:46 AM | #30 | |
13
Rep 33
I also read that the E90s should have an audible prime when the doors are opened or unlocked. However someone above questioned that they had never heard of a car priming the fuel pump before ignition :L Either way, the pump is completely silent until the cranking is over and the engine is running. Seems like the FPR is fixing most issues like this and has the exact symptoms I'm having. I figured it's worth the money to start there like you said, maybe it will fix it and keep me from being embarrassed to start my BMW in a parking lot full of people haha!
- Tempxst
2006 BMW 330I |
06-07-2018, 10:24 AM | #31 | |
17
Rep 328
06-07-2018, 10:44 AM | #32 |
22
Rep 54
I don’t know if this helps you or not, but after hearing your problems I had gone to my e90 06' 330i, and removed the seats to see if there is any prime up related to the pump sound. I for once could not hear any.
I first pressed the start button, and then cranked the car.
E90 330i Euro Spec, Arktis Metallic, Eibach Pro Kit, Rev Motoring Silicone Intake Hose, Turboworks Headers, PI, Milv's, BPC Tune.
06-07-2018, 12:28 PM | #33 | |
13
Rep 33
Hm I did not hear anything there either but I can hear mine kick on once its started. Well I guess I'll report back to you guys once I replace my FPR and see if I can hear it and/or if it fixed the extended crank. I'm ordering this weekend, should have it replaced next week sometime.
- Tempxst
2006 BMW 330I |
06-07-2018, 12:38 PM | #34 | |
1007
Rep 3,895
Drives: 330i, 135i
Fuel pumps on 330s are rare to go bad. These are well made. Check your ground cables, battery, pour in a bottle of injector cleaner. If all these check OK, then most likely is your starter. You dont test your battery by using a voltmeter connected to the terminals. Take it to Auto store and have them do a load test. Fuel related issues are rare on our N52 engines. |
06-07-2018, 02:49 PM | #35 | |
13
Rep 33
- Ground cables have been replaced - Battery is brand new and been registered - Took it to a shop and had the starter tested - Checked spark plugs and ignition coils The only solutions I've seen that worked for people when the starter was good now is: - Fuel Pump - Fuel Pressure Regulator - Crankshaft Positioning Sensor I can go grab some injector cleaner today and dump it in just in-case.
- Tempxst
2006 BMW 330I |
GoRomeo1007.00 |
06-08-2018, 08:40 AM | #36 | |
17
Rep 328
06-08-2018, 11:50 AM | #37 | |
13
Rep 33
- Tempxst
2006 BMW 330I |
06-19-2018, 11:45 AM | #38 |
13
Rep 33
FINAL UPDATE:
Got the new FPR in on Friday and swapped it out on Saturday. Fires up like it should now! Thanks for the info and everyone who helped me sort this out. Hopefully anyone else with this issue finds this thread or the other one before dumping a bunch of money on a new fuel pump, starter, etc.
- Tempxst
2006 BMW 330I |
06-19-2018, 11:47 AM | #39 | |
1007
Rep 3,895
Drives: 330i, 135i
06-19-2018, 12:48 PM | #40 |
Basic Bimmer
520
Rep 935
Drives: E92 328i 6MT ///M
Finally clicked on this thread. Glad you got it sorted!
My car (2013) makes so many noises when it's off, lol. And I haven't taken the time to research them so I have no clue as to what they are (I figured they're all fuel or emissions related, though). I've never seen/heard such in my life. My gf and I sometimes can't help but laugh at it. When you unlock it, open the door, close the door, take out the key, after it's been sitting for a minute... etc... seems like it's always doing something and making wooshing noises ha. |
06-19-2018, 01:41 PM | #41 |
13
Rep 33
Ended up being the Fuel Pressure Regulator as found in the other thread. Fuel pressure was being lost after the car was shut off, also it looks like the top of the assembly may have had a crack in it.
Glad it's over with though, the repair was not very difficult at all and saved me a ton of money! AND now I don't have to feel embarrased to start my car when I walk out to the parkinglot haha!
- Tempxst
2006 BMW 330I |
06-19-2018, 01:42 PM | #42 | |
13
Rep 33
- Tempxst
2006 BMW 330I |
Tags |
e90 electrical, fuel pump, long crank, n52, starter |
