09-17-2023, 08:43 PM | #1 |
664
Rep 364
Drives: 2019 F90 M5 Comp
Level Performance Coolant Catch Pan install
Hello eveyone. I just recorded a DIY install of the new catch pan. Def was an easy install. Should not take longer than 2 hours total.
if you have any questions let me know.
19" BMW F90 M5 Comp
Utku Noa 93 Tune: 700hp/680tq Check out my Socials: https://solo.to/whatsyourforte |
09-18-2023, 12:47 PM | #2 |
1108
Rep 2,325
01-31-2024, 07:14 PM | #3 | |
55
Rep 94
I’m seriously thinking on getting one but not sure if it would be 100% problem proof. |
01-31-2024, 09:39 PM | #4 |
5234
Rep 10,616
You may still be changing your tank periodically. This just reduces the likelihood of more expensive damage. A solution that addressed the underlying problem would be better. For example, heat control that allowed the stock tank to live a long life, or if the stock tanks are simply defective, an aftermarket tank that will live a long life. But to buy a $600 tank cover and still replace tanks at $200 per year seems the least efficient way.
GTTC55.00 |
02-05-2024, 09:59 AM | #5 |
36
Rep 151
Thanks for the diy!! Shoulda went with RK metal tank though. I think that’s the only real solution. It’s 1200 tho but still one time swap and your good. If your keeping the car long term it’s def worth it. Can even Gold dei heat wrap the reservoir to keep the heat away from it.
02-06-2024, 09:54 AM | #6 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
02-10-2024, 08:46 AM | #7 |
Commander USNR Ret
15
Rep 13
I added DEI tape to the Level 1 catch pan. After about 1K miles no leaks thus far.
James' video was super helpful, however I did not have to remove the ecu to complete the install. If I do have further problems, will install turbo/cat blanket. Desire to keep coolant system as close to stock as possible, because of extended factory warranty. |
02-10-2024, 04:45 PM | #8 | |
55
Rep 94
03-13-2024, 06:36 PM | #9 |
55
Rep 94
Finally installed my catch can today. It was a PIA but didn’t have to remove the DME. One downside was the original bolts that hold the expansion tank were too short after install. Lowes did the trick. Another thing to note is the bottom hose goes under the catch can exit nipple/hose, found out the hard way. So far seems ok. If any issues will post again.
03-29-2024, 04:47 PM | #10 |
Commander USNR Ret
15
Rep 13
Update, actually removed the Level 1 catch pan. Coolant tank failed again and coolant leaked thru the two bottom mounting holes. Was barely under warranty, as it expires in April 2024. Dealer replaced tank, 4 injectors on driver's bank as well as coils and harness. Being a boat owner, I think that butyl tape may adequately seal the Level 1, but I will move on to the aluminum RK tank and insulate that with DEI tape. The fact that BMW will not address this problem with a properly engineered solution almost makes we want to sell. . . almost!
GTTC55.00 |
03-29-2024, 06:18 PM | #11 | |
55
Rep 94
03-30-2024, 07:15 AM | #12 | ||
159
Rep 202
03-30-2024, 12:16 PM | #13 |
55
Rep 94
[QUOTE=S EyeLand;31030911]Hmm, this doesn't sound right. Are you sure its seated correctly. I was easily able to use the factory bolts.
Yes, it sits flat with the metal plate without forcing it down. The extra height (thickness) added is not letting the factory bolts to go all the way. Just needed an extra 1/4 of inch or so and it worked. I found it odd too but Its good. |
04-10-2024, 08:48 PM | #14 | |
82
Rep 127
I made a 10k miles roadtrip in M5 across whole USA. My coolant tank started to leak half in to the trip. CCP saved my vacation. Here is a good video demonstrating how it works and reroutes the leaking coolant. In case of extreme big leak, yes, there is a change it will not be able to reroute all coolant from mounting ports. But this is an extreme scenario. Also in this video you can see why RK billet tank is not a solution to a problem: from factory this car is designed to release excess coolant pressure through coolant tank cap. When it does that all this coolant will still go on your engine and injectors. So you still need CCP, even with billet tank Last edited by hookson; 04-11-2024 at 12:22 PM.. |
Holset274.00 |
04-11-2024, 03:58 PM | #15 | |
274
Rep 651
04-11-2024, 04:01 PM | #16 |
274
Rep 651
On the Mhd tune i have checked a box called high performance cooling this lowers the water cooling temp alot when driving hard maybe this can help with this issue?
04-11-2024, 04:31 PM | #17 |
5234
Rep 10,616
Even better with a 90C thermostat. Tunes offer that feature — my BM3 does. But anyone can trigger some degree of supplemental tank cooling by using Sport Plus. Not sure if any of these options alone is enough to reduce heat sufficiently to get a long life from a stock tank. There is a lot of heat from the bank 2 turbine housing and cat just underneath.
