Most power with only a LPFP upgrade? ST or TT?
06-30-2016, 10:51 PM | #23 | |
110
Rep 1,340
07-01-2016, 06:54 AM | #24 | |
2134
Rep 3,554
I dont doubt you made 630 on 93 and meth at 26psi. I do doubt youll be over 700 without PI on e85. There is a thread on the other forum that actually finds the theoretical *ON PAPER* limit of the HPFP and that is 785hp *CRANK*. This is the everything is perfect in the world number, which does not equate to the real world numbers that have been found. Now with meth as supplementary fueling, you are able to supplement the fuel that the HPFP is giving, but you still arent going to hit that 700whp mark. As far as I know, there hasnt been anyone over 700whp without PI. Prove me wrong though if you can. If you cant, gtfo |
07-01-2016, 06:55 AM | #25 | |
2134
Rep 3,554
07-01-2016, 09:30 AM | #26 | |
75
Rep 168
Also I'd be weary of moving 90 whp worth of meth through your charge pipe. Cyl 1 is not getting the same as the others due to the stock manifold design. |
07-01-2016, 01:56 PM | #27 | ||
71
Rep 394
6266 JB 28 psi Stage 2 fuel pump 100% Methanol 93 octane Quote:
08 E82 135 -jpworkz 6870 top mount built motor
10 E92 M3 - Ess 650 Supercharger 18 BMW 530e - stock |
07-01-2016, 02:04 PM | #28 | |||
245
Rep 1,236
2007 e90 335i: Single Turbo 700whp (Sold)
2009 e82 135i: Jb4 Only (Sold) 2010 e92 M3: Macht Schnell Intake, AA Pulley, IPE F1 Full Exhaust, 100% e85, RK Tunes Custom Tune (400whp) |
07-01-2016, 02:33 PM | #29 |
71
Rep 394
Just meth only.
2 CM10 nozzles 180 degrees from each other.
07-01-2016, 03:29 PM | #30 |
654
Rep 946
Still don't see how your keyboard racing has anything at all to do with this thread. My buddy's cousin's rich uncle has a single turbo n54 with 1,300 horsepower. No joke. He posted it online so it must be true.
07-03-2016, 11:15 AM | #31 | |
2134
Rep 3,554
Notice how your hpfp dips the higher in psi you go? Now when you go to use e85 and try to boost 30psi, your hpfp won't be able to keep up. You won't clear 700 without supplementing the hpfp. If you knew anything, you'd be able to tell from the logs. You need roughly 20-25% more fuel vs 93 when using e85 and your hpfp doesn't have 25% to give. Also, port methanol would be 6 nozzles porting directly in to each cylinder like a traditional port injection fuel system. If you are going to go through that trouble for meth, just do the actual port injection. What you talk about with 2 nozzles 180 degrees is just dual meth nozzles which is fine for cooling, but still not the best way to fuel. Last edited by csu87; 07-03-2016 at 11:30 AM.. |
07-03-2016, 10:46 PM | #32 | |
202
Rep 649
17 M3 Comp
07-05-2016, 11:04 PM | #33 |
2134
Rep 3,554
right, its fine for now while he is spraying meth for fueling and running 93oct on 26-28psi and putting down low to mid 600s. running e85 and pushing 700+ likes hes talking about, changes everything.
