01-30-2024, 07:26 PM | #1 |
105
Rep 142
Exhaust clearance
Hey all, anyone have any insight on what the clearance here is supposed to be passenger rear most exhaust hanger bolt? It hits exhaust currently when going over bumps (you can sort of see where the bolt/stud is rounded) and was wondering what my options are. It is stock exhaust. Thanks in advance
02-01-2024, 10:14 PM | #2 |
4141
Rep 7,160
Drives: F90 M5 / F15 50i
I’m curious why they’re moving independent from one another.
'07 Yamaha R1 (sold)
02-01-2024, 10:40 PM | #3 |
5257
Rep 10,629
That is the stud fixed to the body that the hanger bracket and nut attach to. They don’t move independently. The exhaust is moving too much or has moved. The question is why. There are also rubber mounts before the differential that could be adding play. If everything is perfect, I’d move to the front and look at motor mounts.
02-08-2024, 06:43 PM | #6 |
5257
Rep 10,629
A stock exhaust is too loud? In efficient mode? Is ASD active or disabled? Are the valves plugged in? Is this a CS with MPE and no valves?
02-08-2024, 07:24 PM | #7 |
105
Rep 142
Primary and secondary cat deleted asd off can make quieter with valves closed but I lose my burbles and what kind of bmw doesn't have burbles
02-08-2024, 09:04 PM | #8 |
5257
Rep 10,629
That makes sense — it can be quiet if you want. I have primaries and secondaries and ASD delete and titanium valved exhaust and it is civilized in efficient mode and nasty in sport plus.
02-09-2024, 09:37 PM | #9 |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
Garage List 2019 BMW M5 (f90) b ... [9.92]
2021 (F97) BMW X3mc [10.00] 2017 Toyota Land Cr ... [9.50] 2000 Toyota Land Cr ... [0.00] |
Really fast BMW's dont have burble tunes - I had the burbles removed in software - it just sounds like you're trying to hard with them active. AWE isn't all that loud I have the switchpath.
02-09-2024, 09:59 PM | #10 | |
105
Rep 142
Regarding the original thread subject the car is going to be on a lift next Friday so we'll see what the root cause is. Will update when I know more. |
02-10-2024, 11:42 AM | #11 | |
ID10T Specialist
90
Rep 269
Drives: F90 | F97
I had similar clearance issue on my 2019. fixed by loosing the back section and realigning things, basically the whole exhaust, then really fixed when I swapped to the AWE exhaust. |
