BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Diagnostic Mode / JB4 Drive Train Codes
      02-08-2020, 12:22 PM   #1
JBA87
107
Drives: 2019 BMW M5
I just purchased JB4 and installed EWG connectors. Running Map 2 on 2019 M5 Comp. After driving, I obtained drivetrain malfunction alert. JB4 shows the following codes:
2020-02-08 12_50_22:
120700 No Description Found
000000 No Description Found
2020-02-08 13_01_58:
12071A No Description Found
021304 No Description Found
001A01 No Description Found
2020-02-08 13_02_11:
1F2112 No Description Found
2020-02-08 13_20_59:
Terry suggesting I install the firmware update. I believe I did the correctly
Codes still present
He says I need to delete in diagnostic mode
Two questions:
Can Anybody provide color on the above codes
How do I enter diagnostic mode to delete
Any help much appreciated
Also, fuel economy seems horrible after install
      02-08-2020, 03:01 PM   #2
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
Diagnostic mode means you press the start/stop button 3 times with the foot off the brake. That is the only mode the car will allow you to delete codes with.
Mileage isn't going to be effected even if installed wrong so likely you're just racing around more testing stuff.
