02-03-2020, 11:11 AM | #1 |
157
Rep 162
Jb4 Burger tuning F90 meth injection.
Hey old friends!
My car is in the shop for meth injection through Jb4 (burger) Has anybody added it yet. Would love to talk about how works. How to setup the maps. What type of fuel works in conjunction. Meth water ratio? Performance addition? How it actually integrates with the jb4 connect kit If anyone had any numbers as far as quarter mile and 0 to 60 |
02-03-2020, 06:01 PM | #2 | |
575
Rep 754
The way it works if you are using a tune and the JB4 FSB to just control the meth is different than if you are using it with a JB4 and no tune. Either way, it's really easy to turn on and off and the JB4 has some good safety features that work along with it. The advantage of meth is partially to reduce IAT's but you won't see much there. It's biggest factor is to reduce the chance of early detonation which can ruin your motor. The combination of these two allows you to more safely increase timing and boost without the need of race gas. E30 becomes more viable for higher boost with meth than it does alone. It's still a bit sketchy to run it on high boost and 91 octane alone but you can do it to some extent. The air becomes cooler which makes it denser and less air means you have room for more fuel. When the water vaporizes it turns to steam and also acts as a cleaner to your cylinders and piston tops. This same steam acts as a steam engine and pushes down on the cylinder and creates more power. Not much though. It's more of a fuel replacement and cheaper alternative to race gas in my opinion. I wouldn't expect big gains on the track compared to running straight MS109 or something similar.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
02-03-2020, 07:09 PM | #3 |
550
Rep 949
There are a few guys running it on this forum. Main benefits are for those on lower grade fuels. Let's you get similar performance to those on race gas or octane boosters.
02-03-2020, 11:42 PM | #5 |
293
Rep 456
I have the kit and usually run at least E30 with a 91 octane base so I can't really comment. Terry will work with you though. Probably start out with Map 1, get some logs and keep bumping up the boost as long as they look good. Not sure about others, but Map 2 is a sweet spot for me. Averages around 20psi and can do a 10.2 1/4 mile with that. You should have no problem doing that with 91 and meth.
02-04-2020, 11:46 AM | #6 | |
Joint Chiefs of Staff
24193
Rep 190,805
02-04-2020, 11:54 AM | #7 | ||
157
Rep 162
I know how methanol injection works. And I understand the benefits and understand the negatives regarding it. What I wanted to talk about in this forum was regarding people who have it installed on the F90, And how they've experimented with it and what worked for them. What maps, what mixtures, any other changes that might have been made in the JB4 settings. Any gains they may have realized or not. maybe problems they have run into that I should keep an eye on. Just a sort of "things to know" regarding WMI in the f90 specifically. I apologize for rushing my first thread. |
02-04-2020, 01:27 PM | #8 | |
293
Rep 456
As far as negatives about the BMS kit. I noticed the left/right bank boost is not even, because you're replacing the tube that's there to equalized the pressure. Apparently this isn't a big deal because the F10's didn't even have that tube, but I'd still prefer it to be even. Also there's not any good way to mount the tank and motor. It's a PITA to get in where they show it and not way to truly secure it. I didn't notice any gains at all in terms of speed. If you don't have access to 93 or E85, its probably worth doing. If I had to do it again I'd pay up though and get a 2 gallon tank installed in the trunk.
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
02-04-2020, 01:45 PM | #9 |
157
Rep 162
The thing that really makes it worthwhile for me is that I normally (90% info the time) only run 91. And I'm always on map 1 because of that.
Now that I have the WMI Kit I can easily run map 2 or 3 or 8 with my regular fuel. And can easily be turned on and off. Without the WMI kit, it's a real pain in the ass to use any other map other than 1. Sometimes I want my car's Max performance by the push of a button, I feel like with the burger tuning solution (in Jb4) this is really the only way to get it. Essentially I feel like I'm getting two different gas tanks. One with standard 91, and by the push of a button one that equates to a race gas that can run all of my higher boost maps. The biggest value of the meth kit in my opinion is being able to use any of the JB4 maps at any time, without having to pre-meditate my gas settings. |
BMWDriverX365.50 |
02-04-2020, 02:46 PM | #10 | |
366
Rep 804
