BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Not fast enough with jb4
      01-28-2020, 11:04 PM   #23
gpdriver17
293
Drives: F90 M5
Originally Posted by Drew1204 View Post
What is the ratio of the MS101 and 91 you use?
We have (R+M)/2 100 and 104 (I think R+M might be octane rating?) in Arizona which is equal to Research 105 and 110:
https://www.sunocoracefuels.com/fuel/260-gt
https://www.sunocoracefuels.com/fuel/260-gt-plus
Is research 110 higher than VP109?
Could you also say run map 6 on the 100 octane, or would you need the 104?
You can run map 6 on 91 if you set all the values to 0. If you're running any more than 22psi you should probably do the math and get it to around 100 octane.
2018 BMW M5
2018 Porsche GT3
2023 Porsche Macan S
2023 Porsche 911 Turbo S
      01-28-2020, 11:05 PM   #24
Bmwusabmw
21
Drives: Bmw M5
Originally Posted by Hockeytyme View Post
Map2 is an additive map not absolute. I think seeing the csv would help so we can see the DME target.
Right I can see his boost, but i cant see the DME target and how much of the target he is reaching.
In the lower gears I see trims in the low 40s on fairly low boost, i’m more wondering if he is very under the +5 target
      01-28-2020, 11:08 PM   #25
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
EDIT: just re-read your post saying "Anything higher than map2 you need MS109" So then the 260 GT Plus is for anything higher than map 2...?
For map2 I try to be around 98octane minimum to be safe.
For map6 you can run that same 98 but I wouldn't go any higher than 5lbs of boost. Also, be careful with map6. You need to start slow and work your way up and have logs looked at before you go nuts. Map6 boost is completely dependant on what you set it at so go with caution and the help of Terry or someone at BMS. You will need to make changes to other things besides the additive boost targets.
I'm not familiar with the Sonoco Fuels and how they compare to VP unfortunately. I have a VP distributer right by my house so I don't bother with Sonoco
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48
JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18
IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires
      01-28-2020, 11:10 PM   #26
Bmwusabmw
21
Drives: Bmw M5
If he is going with Sun GT260 is his best bet my car loves it, street legal and sold at the pump by me. The GT260 plus uses MMT
      01-28-2020, 11:14 PM   #27
dk79
Drives: 2018 F90 M5 Marina bay blue
Car does not throw any codes at all and drives absolutely fine, smooth. Something is wrong with it, that with tune it's not making enough power.
How do I convince bmw to change the injectors or plugs?
      01-28-2020, 11:15 PM   #28
Bmwusabmw
21
Drives: Bmw M5
Originally Posted by dk79 View Post
Car does not throw any codes at all and drives absolutely fine, smooth. Something is wrong with it.
Add the CSV if you can
      01-28-2020, 11:16 PM   #29
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
It could be a simple fix in the firmware or your wiring. Just email those guys at BMS and send them your logs. They are very helpful!
      01-28-2020, 11:18 PM   #30
dk79
Can I post csv files here or n54tech?
      01-28-2020, 11:19 PM   #31
Bmwusabmw
21
Drives: Bmw M5
Just noticed this but how old is your dragy app? Its not showing DA. Could dragy need an update here too. Have you been updating the JB4 firmware?
      01-28-2020, 11:20 PM   #32
Bmwusabmw
21
Drives: Bmw M5
I would post them there for sure, terry and team will read them too
      01-28-2020, 11:20 PM   #33
dk79
Already sent them csv logs.
      01-28-2020, 11:24 PM   #34
Bmwusabmw
21
Drives: Bmw M5
How is your dragy not showing DA, did you turn that off or is your app not updated?
      01-28-2020, 11:28 PM   #35
Bmwusabmw
21
Drives: Bmw M5
Dme target was default per jb4 map not altered.
Tried but can't load the csv file.
DME target is what the ECU would call for under stock condition as it doesnt know the JB4 is even there...call it the OEM boost profile if you’d like, the JB4 on map 2 then adds to that number (additive boost) to get your total delivered boost.
Example
If DME target was 18 psi, JB4 on map 2 says add 5 psi for a total of 23psi. This is helpful to know if you are under the additive target, and if you are there are ways to fix that with duty bias.
DME target is variable based on engine parameters and can range from 16-22psi.
      01-29-2020, 12:11 AM   #36
dk79
Dragy I guess auto updates.
Will see why it doesn't show da
Da was about 1200
      01-29-2020, 02:19 PM   #37
dk79
Is there a possibility that something is wrong with jb4 unit itself?
      01-29-2020, 06:39 PM   #38
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
Not from what you're describing. Sounds like you just need to crank up the power a little more and get the launch 60' down. 128mph traps are not bad but you should be able to get closer to 130mph.
      01-29-2020, 06:56 PM   #39
dk79
Terry reviewed the csv log files and has asked to increase duty bias by 20 points across the board, and re log on map 2.
      01-29-2020, 09:28 PM   #40
Bmwusabmw
21
Drives: Bmw M5
As suspected under boosting..this is why the DME target vs boost is helpful. - Did you ever check to see how far under the additive target you were?
You should spend an hour or so learning the basics of reading the logs and getting an understanding of what each parameters means. It can save you a lot of time and hassle if you start to think you are having a problem or just want to optimize you maps.
      01-29-2020, 09:51 PM   #41
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
Good points and just to add for OP.
Column "C" is the DME requested target.
Column "D" is the Target. This is what JB4 is adding to the cars DME
Column "E" is the actual Boost that the car is getting.
      01-29-2020, 10:21 PM   #42
dk79
Yes please send me some links, how to.
      01-30-2020, 04:36 PM   #43
dk79
Car still heavily under targeting per csv logs, BMS asked to increase duty bias by another 20 points across the board.
Will update soon.
      01-30-2020, 04:37 PM   #44
dk79
Terry at BMS is superb man, super helpful prompt replies.
Stellar service by burgertining, cuddos to them.
