01-04-2020, 11:00 AM | #1 |
107
Rep 411
Piggy Back v ECU Tune
I am coming from an Audi S6, where there is (to my knowledge) no "piggy back tuning."
Can someone explain to me the operative and implicative differences of a "piggy back" vs. "ECU" tune. I don't full comprehend the difference. Also I'm shopping around and here are the tunes I am aware of (please add to the list) and feel free to comment on the differences: Piggyback JB4 Racechip Dinan Tune Evolve Vivid racing Noelle HCP Dme Eurocharged Any others ? |
01-04-2020, 11:16 AM | #2 | |
64
Rep 157
Drives: 2015 M5 F10
Look at BPM. Mike is very good and you will find nothing but positive reviews for him here and on the F10 forum. www.bpmsport.com |
01-04-2020, 11:25 AM | #3 |
461
Rep 524
On my f90, I've had the following:
First, I installed the race chip on an otherwise stock car. It definitely makes power, but only felt at top end. Car did 10.8 at 128 in florida summer. Then, I had a eurocharged ecu flash (removed race chip). Car was slower....only did 11.0, at same track, and same fuel, and same weather. Low and mid ranges were improved over race chip, but top end was dead. Throttle closures, etc. Removed ec flash and went with weistec ecu file. Strong low, mid, and top end. Car did 10.6 at 130 at same track as before. Great drivability too. Now have stacked jb4 on top of weistec ecu flash. car does 10.2 at 136. We'll do some more tuning on the ecu file in Feb when tuner in town. Car has superb streetability, and is fast. Very happy with this setup. JB4 is a cool tool. Car also has awe intakes, remus catback, and beta tcu tune (will be revised). |
Hockeytyme575.00 |
01-04-2020, 12:00 PM | #4 | |
293
Rep 456
01-04-2020, 01:03 PM | #5 |
550
Rep 949
Hockeytyme575.00 |
01-04-2020, 01:49 PM | #7 | |
Hide! My wife's coming!
812
Rep 2,816
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
01-04-2020, 02:00 PM | #8 | ||
461
Rep 524
01-04-2020, 02:01 PM | #9 | ||
461
Rep 524
01-04-2020, 02:06 PM | #10 | |||
812
Rep 2,816
It's not a knock on them as a shop, it's just with the M5s their tunes suck. Maybe they want reliability but I've had very reliable tunes from others with better results.
01-04-2020, 03:17 PM | #11 | |
767
Rep 1,683
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
01-04-2020, 03:23 PM | #12 | |
293
Rep 456
01-04-2020, 05:38 PM | #16 |
4062
Rep 5,231
Velos also has a tune for the F90 M5.
Lots of information on the Piggy versus tune debate in the F10 M5 forums.
01-05-2020, 09:34 AM | #18 | |
4062
Rep 5,231
Velos has done all of the work on my last 3 M5's and they are very knowledgeable ... not too far from you either. Omar or Carlos can help with any tune questions you may have. I ran their piggy for 5+ years on 2 F10 M5's with zero issues.
01-06-2020, 10:18 PM | #20 |
550
Rep 949
01-07-2020, 03:23 PM | #21 | |
575
Rep 754
JB4 is amazing, and I have set records using it. The thing with JB4 is that anyone can use it just like a flash tune. However, you're limited to some basic setups. Point is, you're not going to put up these crazy numbers unless you have some knowledge, willing to slowly ramp up read logs, test and adjust. If you just want a basic tune using map1 or map2 which is probably the equivalent of a stage 2 tune then go for it. I ran a 10.15 on map2 in my car but I was on 101octane with DP's If you aren't worried about warranty and just want something that you don't ever have to mess with and can just plug and play then a flash tune is the way to go. With JB4 though, not only can I use different maps but each car is different. For instance, map 2 on a certain car will run better than say my car. Especially if you have mods and which modes, which brands etc. With JB4 you can adjust things to work specifically to your car and your mods. Keep in mind, that if you don't want to run downpipes that most if not all tunes will tell you to stick with stage one. However, with JB4 I have seen multiple guys that are completely stock run map2 or map6 with adjustments and run what is equal to a stage2 and put up 10.3's. It's still questionable anytime you run too much boost with stock DP's as the cats can break apart or melt and cause a backup which is not good. I ran a 10.05 on map6 JB4 and a 2.54 0-60 and multiple 60-130 runs under 6.0. I just can't seem to put them all together on one run..haha I had every intention of going with a tune but I see no point when the car is already putting up these kinds of numbers. For daily driving I still run map1 and 91 octane and can put up a 10.3 or add some boostane or pump 101 and run map2 or map6 variation and get a 10.15-10.3 Tunes are the right choice for most people. If you do go with a tune and you want the most power then stick with the ones most guys are using and putting up the best numbers. Evolve, HCP, and DME is also popular but I never see them up high on Dragy. I have seen some Eurocharged but guys that I know haven't had great results on this platform. I would also consider Weistec as they are awesome with Benz and have done a few F90's that are looking legit and the company itself is top notch and local for me at least.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
A Need For Speed377.50 limeypride4423.50 |
01-08-2020, 11:23 AM | #22 |
Joint Chiefs of Staff
24079
Rep 190,597
Correct the bootmod3 is a flash tune.
