BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Dyno Mode? 2 or 4 wheel drive
      12-30-2019, 10:46 PM   #1
Ehloo
549
Drives: 15 x5 m
Trying to figure out if I need to find a 4 wheel dyno. Does dyno mode put the car in 2 wheel drive
      12-31-2019, 02:23 AM   #2
BMWDriverX
Drives: G12 750i X-Drive
4wd only!! If you try to dyno in 2wd mode your car can switch into 4wd mode mid dyno, and kaboom.
      12-31-2019, 08:27 PM   #3
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
Confirmed, I experienced this, too, and it's disconcerting to say the least. In addition, unless you really plan to drive the car in RWD mode, the numbers are meaningless for apples-to-apples comparisons.
      12-31-2019, 08:41 PM   #4
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Interesting. I've never had a car on a dyno, but why would the M5 switch out of 2 wheel drive on a dyno? If it can do it there, is it possible on the street as well? Do the dyno operators explain why this happens?
      12-31-2019, 10:13 PM   #5
BMWDriverX
The car goes ape sh1t because the front wheels are not spinning while the rear ones are.
      12-31-2019, 11:05 PM   #6
limeypride
limeypride's Avatar
Right, but that doesn't explain why it would do it in *dyno* mode.
      01-02-2020, 08:57 AM   #7
JK-M5
JK-M5's Avatar
United Kingdom
61
Drives: MBB F90 M5
just watch evolves dyno using dyno mode on youtube only vid ive seen of this getting done
      01-21-2020, 01:51 PM   #8
prodigymb
208
Drives: V10+ R8, 997TT, Plaid, G550
when engaging dyno mode the car wants to be in AWD mode. i think dyno mode overrides the selections made. i have seen 4 different youtube videos of people running them on the dyno in RWD mode alone.
I confirm that running the car in dyno mode with RWD selected will end in damaged parts. Maybe without dyno mode selected it will work better... but that one I haven't tried LOL
997TT 6MT - 205 mph 1/2 Mile , 170+ mph 1/4 Mile , 3.2 60-130 mph , 2.4 100-150 mph , 1500whp
      01-21-2020, 02:25 PM   #9
limeypride
limeypride's Avatar
Oh no! What happened?
      01-21-2020, 03:49 PM   #10
prodigymb
208
2WD conversion lol
      01-21-2020, 05:08 PM   #11
limeypride
limeypride's Avatar
2WD conversion lol
Oh shit! But from your description.
Would you mind describing the circumstances? Like was it the car suddenly re-engaging 4WD during the test or...
      01-22-2020, 08:59 AM   #12
prodigymb
208
it didn't do anything exciting really. the first pull there was a faint smell of brakes/clutch, we thought it may have been the dyno brake. the second pull it was a strong smell of brakes/clutch and a small cloud of smoke from behind the left front tire which is where the transfer case is located. it also only made 550whp Dynojet which is lower than anything I've seen from Dynojet. We pulled it off the Dyno and onto the street, tried to launch it and it did a 50ft long 2WD burnout and came up with all sort of 4WD malfunctions.
Again we put it into Dyno Mode and then into RWD mode, I think it would have worked if we just put it into RWD mode only. Since I have seen others do this, I have also done burnouts in the car at the track to heat up the tires etc.
      01-22-2020, 09:22 AM   #13
onfireX5
3618
Drives: F90M5,F85X5M
I think Terry smoked one as well on a 2 wheel dyno before anyone knew there was an issue.
      01-22-2020, 11:14 AM   #14
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
I've heard of multiple customers smoking the transfer case doing 2WD dyno runs. It can work but not worth the risk. That transfer case is $6k I think.
      01-22-2020, 11:44 AM   #15
limeypride
limeypride's Avatar
So what does dyno mode do? I've only ever been successful on a Mustang dyno with connected front/rear drums. We simply turned off traction control and that was it—hub dynos and rear-wheel dynos upset the car briefly triggering limp mode.
      01-22-2020, 01:30 PM   #16
prodigymb
208
4,500$
no clue what dyno mode does. maybe shut off the ABS and stability controls.
      01-22-2020, 03:11 PM   #17
Fuel-It!
550
I've only driven an F90 don't own one, but it's supposed to lock the car in 2wd mode. It just doesn't work right.
      01-22-2020, 03:16 PM   #18
limeypride
limeypride's Avatar
Thanks. And agreed; it dropped back to 4WD twice on me on a hub dyno.
      01-22-2020, 07:22 PM   #19
onfireX5
3618
Hub or drum dyno, the best way/safest way and possibly the most accurate way is to use a Linked Dyno. If the operator doesn't understand what that is, go somewhere else. Some ops thinks that any all wheel dyno is linked, but they are not unless specifically built that way or upgraded.
r33_RGSport12912.50
      01-22-2020, 07:35 PM   #20
limeypride
limeypride's Avatar
Agreed. Initially, I couldn't find one hence the other attempts. The Mustang was linked and she gave us a pull every time thereafter.
      01-27-2020, 09:29 AM   #21
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
Wheel speed sensors are the first thing that the DME's pick up as matching the algo's or they don't match. It has a lot to do with real world driving and all the variables that the DME's consider with regards to slippage and grip.
2021 M340i
2020 X3 M40i - her car
2019 M5, AW, DP's, MSR CAI, BM3, SOLD
2020 Chev. ZR2 Bison truck, Daily Driver
      04-04-2024, 10:18 PM   #22
rumeet14
Drives: BMW m5c
bmw m5  [0.00]
So I just had a Shop dyno my car and they asked if it was rwd or awd and I said both and they did the dyno in rwd and I saw it smoke up in the rear but it just smelled like the tires. Then went into awd did 2 pulls lost 70hp on the second one and now everytime I give it gas I get a diff lock code and it reduces all the power in the car. Have any advise on this and what the issue would be? I can’t give it any gas without it throwing the car into limp and it just looses all traction if I give it gas and then goes in limp till I restart the car
