BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Cel code u0115
      12-26-2019, 03:06 PM   #1
m52b2g
8
Drives: m5
Cel code u0115
Has anyone had this error code?
Per online it says ecm/pcm can bus wiring issue
I have down pipe w tune. Seeing if I need to take precautions if needing to take in for servicing
      02-11-2020, 10:45 PM   #2
F80Driver86
G80_Driver
F80Driver86's Avatar
Drives: IOMG G80 M3 Comp xDrive
Hey I have the same code popping up, also have a tune and down pipe.. did you figure anything out by any chance?
      02-18-2020, 06:14 PM   #3
pazosdaniel24@gmail.com
Drives: f90 m5 / jeep trackhawk
I have the same code coming up ... working with bmw tech but still can not figure it out. Let me know if y'all figure it out please. Thank you
      02-18-2020, 06:16 PM   #4
F80Driver86
G80_Driver
Does your check engine stays on or goes away after a little while? Also when the check engine light comes on does it effect the car in any way?
F90_M5_M
      02-18-2020, 06:25 PM   #5
pazosdaniel24
MBEAST
pazosdaniel24's Avatar
Drives: 2019 BMW F90 M5 Competiton
It usually comes up under load and stays on. It doesn't affect the car at all. Just the yellow engine light on...
      02-18-2020, 06:28 PM   #6
F80Driver86
G80_Driver
Oh ok, yes same here it will come on when I take off fast and usually when I take off fast few times, it will pop on and go away within 20-30 minutes, doesn't effect the car as well, looks like we are the only ones that have this problem 🤷*♂️, I will dig around here in Charlotte and see if anyone can figure out what it is, and if you figure anything out plz let me know and I will do the same 👍
F90_M5_M
      02-18-2020, 06:30 PM   #7
pazosdaniel24
MBEAST
Sounds good ! I'll do the same here in Houston. I'll keep you posted 👍🏻
      02-20-2020, 05:56 AM   #8
m52b2g
8
Drives: m5
i never figured out what was wrong, cleared the code and did not come back...yet
      02-23-2020, 10:11 PM   #9
pazosdaniel24
MBEAST
Hey, we tried replacing the valve in the picture ( per my BMW tech) and also change a couple of things with the tune but still go the light/ code today .... 😣
Let me know if y'all got it fix and how please. Thank you again 👍🏻👍🏻
      06-01-2020, 09:39 AM   #10
Griffin337
47
Drives: F90 M5
Did anyone ever figure this out? I just started getting the code and its looks like it is a "permanent" code.
      06-12-2021, 03:22 AM   #11
technik
technik's Avatar
Drives: F82 M4CS, F90 M5, MK5 Supra
Likely torque intervention code. The TCU triggers this DTC when it doesn't receive torque information from the ECU for more than 2 seconds. Would explain why tuned cars are having the issue. The tuner didn't adjust the torque tables correctly for the given power output.
2019 BMW F82 M4CS
2018 BMW F90 M5
2017 MBZ W205 C63S
2018 MBZ W213 E63S Wagon
2020 Toyota MK5 Supra
      06-12-2021, 03:38 AM   #12
technik
technik's Avatar
This DTC has nothing to do with the idle functions in the ECU. The TCU is what triggers the code, not the ECU. Per OBD, this is a "PCM" error -- Powertrain Control Module (otherwise known as the TCU).
2019 BMW F82 M4CS
2018 BMW F90 M5
2017 MBZ W205 C63S
