BMW M5 F90 (2018+) General Forums F90 M5 General Forum    ASD / Exhaust baffle button observations
      09-01-2018, 08:13 AM   #45
onfireX5
3619
Drives: F90M5,F85X5M
Originally Posted by Fegelein View Post
So this fuse pull only eliminates the fake sound?
Any easy pull / fix to keep baffles always open?
I have about 2k on clock now and do notice the exhaust sounding better. Was high revving in 2nd today and when I let off, had couple nice crackles. Still wish exhaust sound was more aggressive, doesn't fully match the M5's capabilities...
Real easy way. Put it in Sport Plus with the Console button lit up. Rev it a couple of times. Shine a flashlight into the exhaust pipe to make sure you did the above correctly (baffles open) then unplug the harness at each baffle.
      09-01-2018, 12:12 PM   #46
Fegelein
Fegelein's Avatar
519
Drives: 2021 X5 M50i
Thanks and harness just hangs there or remains close to orig position?
You put elec tape over it??
First M: New '99 M3 Titanium / Black
Most recently returned: New '18 M5 SG / Black
Current: '21 X5 M50i Black / Black
      09-01-2018, 01:14 PM   #47
onfireX5
3619
Tape it and forget it.
      09-01-2018, 03:42 PM   #48
Fegelein
Fegelein's Avatar
519
So I took a look and I'll never get my hand in there. I'll have my Indy do it, that's installing my reflector delete kit. However, my car was shut off in sport plus with green button on and the flap remained open. Does it automatically revert to closing on ignition?
      09-02-2018, 05:00 PM   #49
TheRealOrosie
BMW Fan Boy
TheRealOrosie's Avatar
Drives: //M
Yes.
      10-13-2018, 01:30 PM   #50
slaweksss
Drives: M5 F90
5. Carefully start pulling the left side panel until you get the room shown in the above pic. Then reach in and unplug the tiny amp.
Thanks for your advice, I found it priceless
I would like to add some optimisation for other guys who will swear on bmw engineers
Left panel is very stiff (at least in European version) so I found it impossible to fold and get access to the amp.
So i recommend to remove additional pushpin: one at the "roof" of the hood located nearby the "grocery hook".
I found it critical to be able to fold the panel.
Than you need to disconnect plastic "frame" around trunk hinge.
I also removed 2 pushpins located behind rear seat - easy fo find when seat is folded down.
onfireX53618.50
      10-16-2018, 11:42 AM   #51
emmfive
emmfive's Avatar
74
Drives: 2001 M5
onfireX5 thanks for the write-up.
onfireX53618.50
      11-03-2018, 11:14 AM   #52
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Pic of the ASD fake Amp and the connector to unplug. It is a personal preference, but I REALLY like it now.
Did mine today, easy instructions to follow, for those who have not yet done it, after removing the for press studs from the plastic surround the latch, lift it straight up when the boot seal is pealed back as there are 4 clips at the back, lifting straight up will save braking any of them.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      11-03-2018, 12:16 PM   #53
GUNGASLOW
192
Drives: 2019 M5
Won’t this throw any codes? I would imagine there would be stored codes that a obd scanner would pick up? Not necessarily a cel on the dash but in the background?
      11-03-2018, 12:22 PM   #54
onfireX5
3619
No. Just took mine in for the recall. Zero issues
      01-22-2019, 08:07 PM   #55
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
Hey guys I noticed on my 19 M5 competition when I drive in sports plus mode with the exhaust button turned on both the ASD sound turns on and the exhaust flap opens up giving out the burble louder exhaust sound.......with the button off it clearly turns the ASD sound off and turns the flap off and reduces the exhaust sound and burbles........so is this a new competition feature? Since theres no need to disconnect the ASD cable nor code it out since its controlled by the button...on another thread 2 other members confirmed this
      01-22-2019, 09:18 PM   #56
onfireX5
3619
I only tested what combo actually controls the valves. ASD is against my religion so I killed it ASAP.
      01-23-2019, 06:54 AM   #57
Steeve19M5CP
194
It actually sounds good on this car and was bad on the F10 M5
      01-23-2019, 07:08 AM   #58
onfireX5
3619
Just depends on what you like.
      01-23-2019, 04:27 PM   #59
brianeck
Part Time Firetruck Crash Barrier
brianeck's Avatar
788
Drives: 2022 M340ix Mineral Grey
I'm glad this is an easy fix again. Once I disabled my ASD on my F80 in never looked back. I picked the car up once from a service and they had plugged it back in without telling me (I think it did throw a code on that car) and I thought there was something wrong with the car it got so much louder and more annoying lol.
I would just mention to please leave it unplugged upon service if it comes up just to save yourself the headache of doing it again - you're not doing anything that will void the warranty.
m340ix Mineral Grey/Tacora Red
      05-08-2019, 12:40 AM   #60
masmole
266
Drives: blue, gray, brown cars
Can anyone confirm if this simple unplugging of the thingie to disable the F90’s ASD will also work the same way on cars equipped with Bowers & Wilkins or does that not make a difference?
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7
      05-08-2019, 05:49 AM   #61
A Need For Speed
A Need For Speed's Avatar
378
Drives: 2019 M5 Comp Nardo/Aragon
"Any easy pull / fix to keep baffles always open?"
How about a video or instructions showing how you did this? Disabling the valve in the open position would be a winner for me, hate starting it up in wimpy mode. Does it have to be on a lift to do this? Thanks.
      06-11-2019, 09:41 PM   #62
soopa
113
Drives: 2018 F90 M5
For those who have disabled the ASD feature...still satisfied with the results?
      06-12-2019, 10:10 AM   #63
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Can anyone correctly summarize what the exhaust button does? I'd still like to figure this out...
My theory:
Engine Setting / Exhaust Button / ASD / Valves
Comfort / Off / Off / Closed
Comfort / On / On / Closed
Sport / Off / Off / Open
Sport / On / On / Open
Sport+ / Off / Off / Open
Sport+ / On / On / Open
IG @windtendo_m5
      06-26-2019, 08:27 AM   #64
NorF90
Drives: M5 F90 1st edt, Z4 G29 M40i
Just coded off the ASD yesterday. I was surprised how much of the engine sound actually came from the speakers.
      02-17-2020, 04:19 PM   #65
idrivem5
can't drive 55
Drives: '17 X5M; '20 M5
I'm looking for a way to code-off ASD on a 2020 M5 w/HK audio system. Following a recent stereo upgrade ASD sounds like a helicopter's in the back seat. Turning off fixes the sound, but also turns my exhaust note from tiger to house cat...
I've been in touch with Technic PNP and BimmerTech. They say there was a change to 2020 models and they're working on the code fix. Hoping there may be someone out there who's already succeeded with this. If yes, please let me know. Thanks!
      02-17-2020, 07:58 PM   #66
A Need For Speed
378
For 19’s, below and Bimmercode app gets rid of ASD along with enables a lot of other great codes. Someone else will have to address if 20’s have a change but can’t imagine why they would.
https://www.amazon.com/gp/product/B0...6WDJ39HA&psc=1
